moj je ovaj http://www.etazgrejanje.com/katalog.php?prodID=17
gledala sam, nigde se ne vidi da curi. A prokljucao je jer je doslo do prestanka napajanja strujom (nemam pojma zasto, elektricar je nesto zabrljao)
Centralno grijanje - Problem sa kondenzom
Pa nije to radila pumpa, uff, nesmes to da dozvolis....
otvo tvoje nije sigurno, greska u konverzaciji, nismo se razumeli, ovo je sporet za centralno grejanje, njegov je toplovodni kotao, dobro si mi rekla da izbegavam sada su mi bas njega pokazeivali sestri, kada sam ja kupovao pec, posto ona planira tako nesto a nju savetuju kao samo taj i nijedan drugi...
mozda nije dobar proracun kotao - radiatori, to je uglavnom problem, pa nemoze da zagreje, pa sta kazu oni, nemoguce da neznaju...
I meni su rekli da je to najbolji kotao na svetu kad sam ga kupovala. Sad kazu da nemaju pojma sta je, nikad nisu videli takav slucaj. A greje super, sve dok nivo te smole ne zapusi dimovodni kanal. Inace, to nije pbicna smola, to je KREOZOT. Evo nasla sam, stavljam link http://www.safesidechimney.com/woodstove.cfm, a evo i deo teksta za ne koji znaju engleski:
The Problem With Glazed Creosote
Glaze is a type of creosote deposit that appears in several forms and can be very difficult to remove. It may only appear as a few shiny patches in the flue or smoke chamber of a fireplace. It may be a thin, even coating up and down your flue and smoke chamber, giving the appearance of being freshly painted with black enamel or high gloss paint. It may appear as a sludgy, tar-like deposit, sometimes even sticky and runny in places.
Whatever the form, it is a problem, and in the event of heavy deposits, a real hazard. On the lighter side, it simply causes corrosion to the system and odor problems. On a more serious note, it creates a fire hazard. A concentrated fuel, it can create the most severe chimney fire.
What Causes Glazed Creosote?
Until the recent advent of modern airtight woodstoves, glaze was hardly seen, particularly in fireplace inserts. It is caused by two things: (1) incomplete combustion in the combustion chamber, and (2) inadequate flue temperature.
Incomplete Combustion
Smoke, simply put, is fuel that didn't burn up in the combustion chamber. Creosote, in whatever form, is smoke that didn't leave the chimney
In order for the wood to burn completely, two things must be present: (1) temperatures in excess of 1100' F, and (2) an abundance of oxygen.
Veliki je tekst, ali stvarno ga vredi procitati.
ma ljudi moji samo treba dobra vatra i kondenza nema...))
jeste a svako vece dok podlozim ono napravi kondez, sta posle snjim....
Ja sam na netu nasla da su 4 glavna uzroka stvaranja kondenzata u peci:
1. dimnjak predimenzioniran ili lose izolovan
2. pec dobro ne dihtuje
3. zidovi peci hladni
4. niska temperatura u peci (priguseno lozenje)
Zamolila sam servisere da pitaju inzenjere iz Centrometala da li bi bia dobra ideja da ubacim kamenu vunu izmedju tela kotla i njegove obloge, te da na taj nacin smanjim ishladjivanje lozista.
Vise bih volela da su mi vratili pare, pa da vidim sta cu, ali kad pogledam da garanciju daje proizvodjac a ne prodavac, onda moram da budem zadovoljna. Videcu sta i kako ce se ponasati ovaj novi kotao...
pa uzmi podloži otvori sve cugove... i ako šta napravi kondenza, uzmeš odma digneš temperaturu na 90 da to sve spali jedno destak minuta i onda lagano spustiš temperatutu na 72 je radna temperature kod mene, na primer... i ne smije tako da kondenzuje... kondenz najčešće nastaje kad se loži i gasi peć...
Avaks,
da je mogla da se spali, spalila bi se prosle nedelje kad mi je blokirala pumpa, pa je temperatura otisla na 120C i tako drzala cela dva sata. Kad je pala, ja sva srecna pogledam unutra, a ono smole za izvoz!
A de ti meni reci kakvo ti gorivo trošiš? Kakva drva? Ugalj? Zar je moguće tolika smola da bude?
Prosle godine nisam lozila drvo, koristila sam ga samo za potpalu i to suve grancice od tresnje, kajsije i loze.
Ove godine lozim drva od kajsije i ugalj suvi vreoci od prosle godine. Sve suvo kao barut.
Gledam moje komsije kupuju drva secena pre mesec-dva, a nigde smole kod njih.
Probala sam i sa bukovinom (dao mi komsija koji je stavio gorionik na pelet), ali ista stvar.
Sledece nedelje cu dobiti novi kotao, pa me bas zanima kako ce da radi. Ipak, moram priznati da mi je briga veca od znatizelje...
Kod mene se pojavi kondenez kada naložim vatru i taman što se temperatura popone na 70, pumpa se uključi i onda temperatura počne da pada i pana na oko 50 i tada nastaje kondenz i posle kada temperatura vremenom poraste bude sve ok. Bez kondenza... A ajde vidjećemo šta je i kod tebe.. Pa da to zalijemo? A da nisu podzemne vode???
Pa to je, brate mili! Kako se nisam toga setila? ))))))))
Bili su mi serviseri i poudili mi da mi vrate novac. Da li da se radujem ili da lupam glavom o zid?
Sad sam u dilemi koji kotao da kupim. Izbor mora da bude neki koji moze da ide na dimnjak 160mm visine 8m i mali gabarita.
Dodatni problem je sto u svakom slucaju moram da srusim zid kotlarnice i da prebacim vrata, jer drugacije necu moci da udjem u nju.
Prva varijanta je Radijator Kraljevo 18kw model FK sa prinudnom promajom. U prospektu pise da se lozi na 24 sata. To mu je velika prednost, ali se plasim da mu je snaga mala za mojih 120m2. U slucaju da se odlucim za njjega, planiram da stavim stiropor na tavanicu sprata. Znam da je bolje da ga stavim na pod tavana, ali to mi je neizvodljivo jer mi je na tavanu uzasan lom i previse stvari. Sa druge strane, sve dosadasnje kotlove sam lozila samo kad dodjem sa posla oko 18h i jos jednu vatru oko 21-22h. Temperatura je bila sasvim zadovoljavajuca, pa bi verovatno bilo dovoljno i ovih 18kw kad se lozi 24 sata.
Druga varijanta je BOSCH solid 2000H, dvopromajni, 24kw. On me je privukao zbog toga sto se prodaje i kao pelet set, sto bi znacilo da je dobra iskoristivost pri grejanju na pelet, pa kao, eto, kad skupim opet krvavo neku kintu, mogu lako da predjem na pelet.
Treca varijanta je Ferroli, takkodje zbog dimenzija i zbog peleta, ali nisam nasla koliko kosta.
Cetvrta varijanta: Centrometal CKP 20kw (a onoliko sam ih pljuvala na sva usta)
Prva dva kotla imaju slicnu cenu, oko 1000 Eura.
Volela bih jos necije misljenje, jer moram brzo da odlucim (zima sve blize i panika me hvata)
- ma moj predlog ti je kotao na struju i garant će dimnjak moći... šalim se. Kupi taj BOŠ, ima ga moj prijatelj i dobar je sasvim je zadovoljan sa njim, samo što je kod njega malo veći od 32 kW, ali je ista serija i on je sasvim zadovoljan ali ja nisam.. Kod mene i dalje voda curi polako ali sigurno...
Avaks, care! A koji je tvoj kotao? Znamo da je 32kw, ali koja marka?
Ljudi, meni jos nisu odneli ktao, pa danas reko' hajde da malo nalozim. Otvorim ja onu klapnu sto usmerava pravo u dimnjak (ona koja se otvara dok se podpaljuje), i kad se digla temperatura, ja da zatvorim klapnu, ali -vraga. Naravno, &%@#$ se zaglavilo. I temperatura, naravno, nece da sidje sa 80C. Pogledam ja unutra, vatra picki k'o luda, a smola curiiiiii.....
Nego, da li hoce neko parket da lepi, pa d mu skupim malo smole? A mogli bismo Avaks ti i ja i firmu da otvorimo pa da prodajemo smolu...A?
zdravo,dali neko moze da mi kaze sta da kupim za grejanje. imao sam central 20 i sa njim sam bio zadovoljan medjutim procureo.sta sad da kupim ?
zoranp970, sapatnice! Pa mi ovde samo kolektivno kukamo, pitamo, pa onda ne poslusamo savet, da bismo mogli opet da kukamo i druzimo se
sto nekupis istu kada si zadovoljan, meni je megal procurela posle 7 godina, bila je 40 ili 44 kw ako me secanje sluzi, zvaku pec sam pogledao i nalozio, uzeo bih sigurno wiadrus u 24 po meni najbolja, ali nije za neki kombinovan ogrev, unutra je loziste uze pa drva znaju da se zaglave, a za ugalj je vrh, e to je jedini razlig zasto nisam lju uzeo, nakraju uzmem opet megal, mozda sam se zjbo, al nisam uzeo majstora da montira jer je sve isto, samo am uzeo 32 na dvesta i neto kvadrata, nema izolacije drveni prozori, da ne poverujes, jos bolje greje iako je manja a manje trosi (manje loziste), uzeo sam je iz razloga sto zimi imam 10 000 dinara buzdet za ogrev i prolazim celu zimu, grejao sam se na neki odpad od sirove gradje, 5-6 kubika 2 500 dina, i doteram 2 prikolice drva iz sume drva, za imam noc, imam malu bebu a u kuci mi je od 24 pa do 27 stepeni, i tako ceo dan i celu noc, ali meni kada zafali istovare u sneg kamion i tako sa sve snegom sam ubacivao taj otpad u kotao, pored toga nisam imao regulator promaje pa sam gusio sa klapnom, to je kondezovalo sacuvaj boze, e nadam se da ce trajati malo duze jer sada imam gde da susim ogrev i imam suv, nije od prosle godine al je suvlji, ja sm se plasio da se nesjbem nesto, i na kraju sa nekom drugom, neznam koliko megal ima stepen iskoriscenja ali mi se naavise svidja raspored promaja?
znaci svako djubre od peci ce da ti procuri, na svaku marku peci kukaju, to je cinjenica, rok trajanja, livene nece al vise trose, ti vidi sta tebi odgovara, livena i varena su ti kao stari dizeli i benzinci, varena je kao dizel, manje trosi vise je zahtevna oko odzaka promaje i ogreva, pa jos trajnozareca tropromajna vise zahteva, ali manje trosi, a livena je kao benzinac, odma gazis iako je ladan guta sve zivo, ali vise trosi,
ako lozis (solidan a ne neki lignit i neko djubre, recimo banovic orah ili resavica, najbolje ruski, taj nemozes da pogresis bolje greje, manje pepela, i manje trosi, onda uzmi i za jedno rabro manju, ha ha ha) ako je ugalj i po neko drvo samo viadrus ali samo u24, i uzmi knap za tvoju kucu, proveri samo dali dimnjak moze za nju, mora da je visok i izolovan .....
Probat cu da vam pomognem iz mog ugla interesovanja.Kondenz ili kondenzacija je ostvariva ako se stvore uslovi zato . Na prvom mestu temperatura pa onda pritisak koji su jos upravo srazmerni>Da ne davim ,kada se poklope potrebni parametri ,gasovita vlaga ( vodena para ) prelazi kriticnu tacku imenja agregatno stanje u tecno.Rafinerije ,destilerije i drugi koriste ovaj princip za dobijanje selekcija. Aa vama to ne treba ,vas cilj je da se resite dima pa pravite i siroke i visoke odzake.Mislite da ako menjate lozace ,kotlove i vrstu ogreva resavate problem?Resenje je u cistoj fizici .,Vas odzak ne sme da udje u kritichnu temperaturu do samog vrha odzaka..Ako se to ispostuje onda nema vlage isigurno nema dima u kotlarnici jer takav odzak "vuche".Mozete da lozite i suvu drenovinu ako vam je odzak podlozan kondenzu samo cete smanjiti kolicinu kondenza.Pre svega dimenzionisite sirinu i visinu odzaka ,izolujte celom visinom odzak i predihtujte dimnjacu kako nebi vukla falsh vazduh. .ps Naravno podrazumeva se da vlaga ne dolazi iz kotla .............mozda nekom koristi ali zasigurno ne shkodi..... . poz.
Kotlovi Termomont su odlicni.Ja imam TZK 52 i prezadovoljan sam.Kad mu uhvatis verak,on radi samo tako. Sad sam ugradio i gorionik na pelet isto Termomont Biotermec.Super stvar. Odlicno greje,drzi dobro temperaturu,a i vidim da je izradjen od debelog lima 5 mm i garancija kotla je 5 godina.
Pre svega, pozdrav.
Negde sam pročitao da smola i kondenzacija (voda) nisu isto. A ja imam oba.
Imam kotao Junkers Supraclass S 27 kW, a dimnjak je 7m (od čunka). Kuća 140 m², prizemlje, sprat + potrkrovlje (neizolovano), kuća takođe neizolovana, sa fasadom.
Prošle godine je ložena sirova kolubara (stigla u oktobru) + drva (dovučena tokom leta). Bilo je smole, u ložištu samo, nešto malo i to je to.
Ove godine ložim suvu kolubaru, bez drva, čisto preko noći neko deblje drvo da ima žara ujutru (grede neke od stare šupe, suvo ko barut). Sa loženjem samo počeo 10. oktobra, trošeno 2-3 kofe dnevno. Sve na kotlu pozatvarano stalno, jer je znao da nakucava temperaturu, a i radijatoru su bili vrući, tako da nije bilo potrebe da otvaram.
Do pre par dana sve normalno, i odjednom počinje da dimi iz kotla, da spušta naglo temperaturu čim se upali pumpa itd.
Jutros, tokom čišćenja kotla vidim da je na dnu srednje promaje pliva 2-3 cm što smole, što vode, po zidovima na sve tri promaje, voda i smola u pepeljari u delu iznad onog tanjirića u srednjoj promaji.
Otkud ovoliko kondenzacije, sa suvim ugljem? Gorepomenuto, prošle je bilo mnogo manje, samo u ložištu.
Kotao i dimnjak očišćeni pre početka sezone.
Hvala unapred.
Pisem i u ovu grupi jer imam problem koi jos ne mogu da uklonim, a problem je sledeci ali prvo da se izvinim na losem pravopisu jer sam iz Makedonije Smile , imam kotao sime soleta EV 5 45 kw, na cvrstom gorivu (drva) kotao je smescen u podrumskom delu kuci ( iznad je ducan, pa iznad njega je sprat gde zivim i provodim vise vremena a iznad je jos jedan 3 sprat) medjutim imam kondenzaciju u kotao i na zidu na najgonijem spratu gde prolazi dimnjak i stvara crnu mrlju na zidu.Kuca je stara 7 godina i je dobro izolovana . Pre 10 dana sam ugradio cetvoro kraki mesajuci ventil kao sto se vidi na slici, ali problem u kotao jos mi nije sasvim resen, opet stvara kondenzaciju pa bih zeleo neko ko je kompetentan da mi da neku ideju sta da radim i dali mi je dobro ugradjen i kako mi je nastelovan.
Hvala vam unapred svima
Ljudi pomagajte..Imam od prosle godine Viadrus U22 i lozim drva i ugalj (banovice) javlja mi se kondez niz cunak koji ide u dimljak crna voda a smola mi se lepi na vratima da ujutru jedva mogu da ih otvorim.Odzak je visok 12-13 m domacinski oblozen sidel fi najveci i cigla,stiropor,fasada..domacinski.Onaj lanac imi je ispao pre par dana i sada ne znam da li sam ga dobro vratio jer mi je podesen na 60c. onaj regulator na peci i tada je klapna zatvorena .Takodje kada sam cistio pec skidao sam pozadi onu klapnu za prigusivanje i sa jedne str je okrugla sa druge zasecena i to da li ima neke veze kako li se okrene jel puno dimi i vraca dim na vrata kada su otvorena i pozadi na one rupe od osovinice koje vire od klapne..Sta uraditi da se resi problem dima,kondeza i da li taj lanac dobro stoji na 60c??? Ne znam ni kako podici temp na tom tockicu a skidao sam ti sipku i onaj krak sto ulazi u njega i kako kod da nastelujem uvek mi stoji na 60c ,podizem tako sto lanac podignem pa kada nabije temp.vratim ga.. Takodje na cevima mislim da imam trokraki ima neki regulator da ga tako nazovem ima skalu od 0 pa 5 pa 10 mislim da je to taj trokraki..Da li je mozda dimljak zapusen radio je samo jednu sezonu..Probao sam cak i sa vodom i prasnom da zapusim te rupe i spojeve na toj osovinici of klapne i spojevima od cevi dimljace ali ispucaju...Pec se cisti redovno..sta da radim i da li mi iko moze pomoci..Hvala
Cime se lozi?
Drva i ugalj mezgraja
Postovani, imam kotao megal trajnozareci 25 kw kupljen pre 3 godina nov i dimnjak zidan od elemenata 8,5m plus izolovan stiroporom 10cm, Od prve godine koriscenja mi curi kondenz na donjim bocnim otvorima za ciscenje. Imam i mesaoni ventil i kotao radi na 70 stepeni, grejem oko 150 m2 i sve je ekstra osim smrdljivog kondenza. Sta se jos moze uraditi po tom pitanju?
Od kada su drva? Da nisu sirova? Kolika je temperatura na povratnom vodu u kotao?
Drva od prosle god a temperaturu na povratnom vodu ne znam, ali ne moze da bude mala kad kotao radi na 70 a ja u kucu pustam 40
Pa ako imate samo pumpu u potrosackom krugu i cetvorokraki ventil, povrat u kotao moze biti i ispod 40 C
nemoj da se dzabe obradujes dok ne saznas cinjenicu dali curi stvarno,
pa nemogu da se setim, ali mislim da nov isto godiste kao tvoj, e pre toga nije valjala serija mislim pre 2009, znaci 2008 ima neku razliku oko vrata, ovakva ili onakva nesecamm se, videces sta ti donesu dali ima razlike, pogledaj ti dali ti je mokar pepeo dole kod vrata kada je hladna, mora da pokaze tu gde curi, mora da se sliva negde to sto izlazi, jako jako malo, gde posumnjas obrises nekom krpetinom pojavi se ponovo posle par minuta, ( kad se ugreje mnogo se brze prazni voda), pa nece da gori, pa mora da je otvoren cug, pa ostane drvo koje nije izgorelo, pa padne pritisak, pa gornji radiatori nerade, pa nema vazduha da se ispusti nego jos usisa vazduh u radiator a nigde necuri, itd... uzmi baterisku lampu i gledaj dali curka negde, ali kda kada je hladan da se neopeces, a mozda je prokuvao sto je ostao bez vode, samo nemoj rano da donosis zakljucke, prvo proveri pa onda, kotao je parna masina, mnogo komplikovana kao motor na kolima, samo sto je ovde u kontroli ljudski faktor, moras dobro da se upoznas sa tematikom, to ispitaj ove koji ti zamene kotao oni znaju sta je sigurno, to je isto kao tebe neko kada bi pitao nesto zasta si ti strucna, ne moguce da ne znaju, jedino da se prave ludi .....
znaju oni sa to iznad vrata, za tu seriju, pitaj ih ?
on je mene savetovao ovakav da je dobar kao, samo sto je malo tamnija boja plava kako mi se cini njegov
http://www.dzonikom.com/cenovnik.php?otvori=tip&idp=1&idk=1&idg=31&sl=ek...
