Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:9496b9d3dd62260f2c84706e53157a1f'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/instalacije-grejanja-i-klimatizacije/alfa-term-topla-sanitarna-voda-iz-cijevi', '', '172.69.58.238', 1748663064) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:1107:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Poštovani imam alfa term štednjak na etažno grijanje. Koristim otvoreni sistem etažnog grijanja te me zanima da li mogu koristiti cijevi za hlađenje kako bih imao toplu sanitarnu vodu na sudoperu. Te cijevi za hlađenje služe ukoliko se radi o zatvorenom sistemu grijanja, kada se kotao pregrije onda termoventil pusti hladnu vodu iz vodovoda s jedne strane u spiralu koja je u kotlu a s druge ta voda izlazi u odvod i na taj nacin se obara temperatura u kotlu. P in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '2:abfecc63f09f063c306e2753273f32e4'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/instalacije-grejanja-i-klimatizacije/alfa-term-topla-sanitarna-voda-iz-cijevi', '', '172.69.58.238', 1748663065) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:942:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = '<p><iframe id=\\'a431a3a0\\' name=\\'a431a3a0\\' src=\\'https://adserver.samsvojmajstor.com/adserver/www/delivery/afr.php?zoneid=26&cb=9900435235423422\\' frameborder=\\'0\\' scrolling=\\'no\\' width=\\'728\\' height=\\'90\\'><a href=https://adserver.samsvojmajstor.com/adserver/www/delivery/ck.php?n=afcbc006&cb=9900435235423422\\&#0 in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:19fe8dbf11d573b5bff835ce9a54f312'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/instalacije-grejanja-i-klimatizacije/alfa-term-topla-sanitarna-voda-iz-cijevi', '', '172.69.58.238', 1748663065) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:694:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Portal za sve ljubitelje majstorija, ručnih radova i ljude spretnih ruku. Ovde možete razmeniti iskustva, znanja i podatke o sitnim ili krupnim majstorskim radovima, u kući na radnom mestu, u bašti i i naučiti neku novu veštinu i pomoći vašem usavršavanju, a znanje i iskustvo doprineti bogatstvu ovog foruma.</p>\\n<p>Želimo Vam puno mašte i ugodan boravak na našem portalu.</p>\\n ', created = 1748663065, in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '2:ca011fdebe3a51dea5859d4aba19f564'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/instalacije-grejanja-i-klimatizacije/alfa-term-topla-sanitarna-voda-iz-cijevi', '', '172.69.58.238', 1748663065) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:956:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = '<p><iframe id=\\'a354bc39\\' name=\\'a354bc39\\' src=\\'https://adserver.samsvojmajstor.com/adserver/www/delivery/afr.php?zoneid=27&cb=002874370149734552\\' frameborder=\\'0\\' scrolling=\\'no\\' width=\\'234\\' height=\\'160\\'><a href=\\'https://adserver.samsvojmajstor.com/adserver/www/delivery/ck.php?n=aa83fdd3&cb=0028743701 in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Alfa term - topla sanitarna voda iz cijevi za hlađenje
