ANBRIKOVANJE - opravljanje rutera kada zakuca i trepce mu power led
ovaj video je za sve kojima se pokvario ruter ovaj tip kvara za ruter linksys 54gl v1.1
dakle pogledajte video> https://youtu.be/h9tDEPtyD1E [1]
First set static ip 192.168.1.10 subnet 255.255.255.0 gateway nothing dns nothing
Second conect bricked router with utp cable on your pc,download tftp app than go to routers official versions firmware adress www.ddwrt.com [2] and download firmvear for your specific router with name tftp firmvare ... like v1.1flashing via TFTP.bin download and click on tftp app set ip 192.168.1.1 load tftp.bin fw and click upgrade when upgrading done than will be green circle that mean you succesfuly debricked router he will be blicking and stop for sure preformances plug out than plug in adapter cable from router like on video than go on 192.168.1.1 if you are able to load that page after debricking you succed
[1] https://youtu.be/h9tDEPtyD1E
[2] http://www.ddwrt.com
[3] http://www.samsvojmajstor.com/portal/forums/uradi-sam/ku%C4%87na-tehnika/ddwrt-linksys-54gl-v11-unbrick-odcikgavanje-kada-trepce-power-led-anb#comment-432955
[4] http://www.samsvojmajstor.com/portal/users/bebel
[5] http://www.samsvojmajstor.com/portal/forums/gradjevinarstvo/elektroinstalacije/povezivanje-kabla-na-shporet#comment-432956
[6] http://www.samsvojmajstor.com/portal/forums/uradi-sam/ku%C4%87na-tehnika
This comment has been moved here [5].
