Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:527972815269c91a1ea5c9e319c65313'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/izolacije/kako-zatvoriti-otvor-prema-potkrovlju', '', '108.162.216.240', 1748707583) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:1054:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Iz dnevnog boravka su stepenice za potkrovlje koje se za sada neće grejati.U dilemi sam kako rešiti da topao vazduh ne odlazi gore.Otvor iznad stepenica je cca 2 m2 u L-obliku.Dakle ,plan je napraviti nekakav pokretni poklopac .E,pitanje je od čega.Da li je npr,dovoljno iseći lesonit ploču(ružno???) i položiti je na otvor sa gornje strane?Druga ideja mi je poslagati stiropor ploče od 2 cm u potrebnom obliku,povezati ih mrežicom i lepkom,pa pogletati,možda in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:039036a9be855a6dc901c870b1187a71'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/izolacije/kako-zatvoriti-otvor-prema-potkrovlju', '', '108.162.216.240', 1748707583) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:447:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Konstrukcija od drvenih letvi, u obliku otvora. To će dati čvrstinu i oblik. Preko letvi može bilo šta. Najjednostavnije (po meni) je beli lesonit.</p>\\n ', created = 1748707583, expire = 1748793983, headers = '', serialized = 0 WHERE cid = '3:039036a9be855a6dc901c870b1187a71'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:3d57d580638b6ab2348db89f47054b67'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/izolacije/kako-zatvoriti-otvor-prema-potkrovlju', '', '108.162.216.240', 1748707583) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:343:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Nema glupih pitanja. Ima samo glupih odgovora !</p>\\n ', created = 1748707583, expire = 1748793983, headers = '', serialized = 0 WHERE cid = '1:3d57d580638b6ab2348db89f47054b67'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:108;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/ in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '2:abfecc63f09f063c306e2753273f32e4'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/izolacije/kako-zatvoriti-otvor-prema-potkrovlju', '', '108.162.216.240', 1748707583) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:942:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = '<p><iframe id=\\'a431a3a0\\' name=\\'a431a3a0\\' src=\\'https://adserver.samsvojmajstor.com/adserver/www/delivery/afr.php?zoneid=26&cb=9900435235423422\\' frameborder=\\'0\\' scrolling=\\'no\\' width=\\'728\\' height=\\'90\\'><a href=https://adserver.samsvojmajstor.com/adserver/www/delivery/ck.php?n=afcbc006&cb=9900435235423422\\&#0 in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:19fe8dbf11d573b5bff835ce9a54f312'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/izolacije/kako-zatvoriti-otvor-prema-potkrovlju', '', '108.162.216.240', 1748707583) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:694:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Portal za sve ljubitelje majstorija, ručnih radova i ljude spretnih ruku. Ovde možete razmeniti iskustva, znanja i podatke o sitnim ili krupnim majstorskim radovima, u kući na radnom mestu, u bašti i i naučiti neku novu veštinu i pomoći vašem usavršavanju, a znanje i iskustvo doprineti bogatstvu ovog foruma.</p>\\n<p>Želimo Vam puno mašte i ugodan boravak na našem portalu.</p>\\n ', created = 1748707583, in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '2:ca011fdebe3a51dea5859d4aba19f564'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/print/forums/gradjevinarstvo/izolacije/kako-zatvoriti-otvor-prema-potkrovlju', '', '108.162.216.240', 1748707583) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13) query: INSERT INTO watchdog (uid, type, message, variables, severity, link, location, referer, hostname, timestamp) VALUES (0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:956:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = '<p><iframe id=\\'a354bc39\\' name=\\'a354bc39\\' src=\\'https://adserver.samsvojmajstor.com/adserver/www/delivery/afr.php?zoneid=27&cb=002874370149734552\\' frameborder=\\'0\\' scrolling=\\'no\\' width=\\'234\\' height=\\'160\\'><a href=\\'https://adserver.samsvojmajstor.com/adserver/www/delivery/ck.php?n=aa83fdd3&cb=0028743701 in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
Kako zatvoriti otvor prema potkrovlju?
