Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13)
query: INSERT INTO watchdog
(uid, type, message, variables, severity, link, location, referer, hostname, timestamp)
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:00d67dcf57d377c343e53ec8c64d759c'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/sam-svoj-majstor/elektri%c4%8dni-trimer-na-solarno-napajanje-0', '', '108.162.216.229', 1748627704) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:1005:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Pozdrav svima.<br />\\nPošto imam jedan električni trimer AC220v i solarne panele 2x 275W odlučio sam isprobati kako bi to funkcionisalo zajedno i da napravim da trimer radi direktno preko solarnih panela bez korištenja akumulatora. Ovako izgleda taj moj projekat a da li neko zna kako bih mogao usavršiti ovaj moj sistem da ga koristim direktno sa strujom koja dolazi sa solarnih panela bez korištenja akumulatora?. Da li da ceo sistem povežem nek in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:aa98b48306647786b9f72b3df63faeb2'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/sam-svoj-majstor/elektri%c4%8dni-trimer-na-solarno-napajanje-0', '', '108.162.216.229', 1748627704) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:1342:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Grom me ubio ako ja kontam kako ovo felcera???<br />\\nTrimer koji radi na deklarisanih 220v AC, naizmjenicne struje, radi na 160v jednosmjerne.</p>\\n<p>I ovi clanovi koji se ozbiljnije bave elektronikom ce to sigurno malo bolje objasniti, ali ovo iznosenje amperaza i uporedjivanje baba i zaba po meni nema veze sa zivotom. Moguce da grijesim, ali volio bi da naucim kako ovo felcera. </p>\\n<p> A in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:44c6ed5876dfb90220e7c20902c050f5'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/sam-svoj-majstor/elektri%c4%8dni-trimer-na-solarno-napajanje-0', '', '108.162.216.229', 1748627704) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:1426:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Pa imas invertere sa preko 90% iskoriscenja, tako da dobijes skoro ulozeno na izlazu. Tako da su relativno mali gubitci.<br />\\nNajvise sto sam ja sreo je manje od 5% gubitaka, doduse za puno manje snage.</p>\\n<p>Ovde je najveci problem sto nema pracenja maksimalne snage panela. Pa nikad iz njih nece dobiti ni blizu 275W.</p>\\n<p>A motor sto ne bi radio? Njemu sve jedno da li je DC ili AC. To in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:190166f1660489a34625c6ef4fd74456'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/sam-svoj-majstor/elektri%c4%8dni-trimer-na-solarno-napajanje-0', '', '108.162.216.229', 1748627704) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:521:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>evo jos takvih snimaka<br />\\n<a href=\\"https://www.youtube.com/watch?v=mgMcuXawwiQ\\" title=\\"https://www.youtube.com/watch?v=mgMcuXawwiQ\\">https://www.youtube.com/watch?v=mgMcuXawwiQ</a></p>\\n ', created = 1748627704, expire = 1748714104, headers = '', serialized = 0 WHERE cid = '1:190166f1660489a34625c6ef4fd74456'\";s: in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:9af8e401604c025db849e4748086ab3d'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/sam-svoj-majstor/elektri%c4%8dni-trimer-na-solarno-napajanje-0', '', '108.162.216.229', 1748627704) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:811:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Izvinjavam se, zaista nisam nikad ni probao ac cetkas spojiti na dc struju jer mi je bilo nelogicno da moze da radi. </p>\\n<p>Sto se invertera tice, oni vuku poprilicnu amperazu da bi prebacili napon na 220v i kod mene invertor od 1000w max je za nekih 500w snage potrosaca vukao valjanih 40-50tak ampera na 12v, mozda i malo vise. </p>\\n<p>Nisam rijesio masinu, dao sam nekom elektronicaru da je proba i kaze da in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:7c342c005133dd292cca19753aeed4b6'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/sam-svoj-majstor/elektri%c4%8dni-trimer-na-solarno-napajanje-0', '', '108.162.216.229', 1748627704) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:874:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>To je ok potrosnja. 12vx50A to je 600w.<br />\\nPri 50A sigurno nije bilo 12v na aku. Nego je pao napon.<br />\\n20% gubitaka je prihvatljivo.</p>\\n<p>Zato solarni sistemi rade na vecim naponima. Ima ih i preko 500v sa panela. Pa je struja manja, i samim tim gubitci manji u odnosu na sistem sa manjim naponom.<br />\\nOvi stepup su puno efikasniji od dc/ac invertera. Tako da dva spojena ovako na r in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '2:abfecc63f09f063c306e2753273f32e4'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/sam-svoj-majstor/elektri%c4%8dni-trimer-na-solarno-napajanje-0', '', '108.162.216.229', 1748627704) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:942:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = '<p><iframe id=\\'a431a3a0\\' name=\\'a431a3a0\\' src=\\'https://adserver.samsvojmajstor.com/adserver/www/delivery/afr.php?zoneid=26&amp;cb=9900435235423422\\' frameborder=\\'0\\' scrolling=\\'no\\' width=\\'728\\' height=\\'90\\'><a href=https://adserver.samsvojmajstor.com/adserver/www/delivery/ck.php?n=afcbc006&amp;cb=9900435235423422\\� in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '2:ca011fdebe3a51dea5859d4aba19f564'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/sam-svoj-majstor/elektri%c4%8dni-trimer-na-solarno-napajanje-0', '', '108.162.216.229', 1748627704) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:956:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = '<p><iframe id=\\'a354bc39\\' name=\\'a354bc39\\' src=\\'https://adserver.samsvojmajstor.com/adserver/www/delivery/afr.php?zoneid=27&amp;cb=002874370149734552\\' frameborder=\\'0\\' scrolling=\\'no\\' width=\\'234\\' height=\\'160\\'><a href=\\'https://adserver.samsvojmajstor.com/adserver/www/delivery/ck.php?n=aa83fdd3&amp;cb=0028743701 in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '2:64a277481435f3c6a7b18eb6fa57f957'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/sam-svoj-majstor/elektri%c4%8dni-trimer-na-solarno-napajanje-0', '', '108.162.216.229', 1748627704) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:868:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = '<p><iframe id=\\'a694a55c\\' name=\\'a694a55c\\' src=\\'https://nepremicnine.click/www/delivery/afr.php?zoneid=99&amp;cb=43241234\\' frameborder=\\'0\\' scrolling=\\'no\\' width=\\'300\\' height=\\'600\\'><a href=\\'https://nepremicnine.click/www/delivery/ck.php?n=a9f8f8a5&amp;cb=63456\\' target=\\'_blank\\'& in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135 Električni trimer na solarno napajanje | www.samsvojmajstor.com
Pozdrav svima.
Pošto imam jedan električni trimer AC220v i solarne panele 2x 275W odlučio sam isprobati kako bi to funkcionisalo zajedno i da napravim da trimer radi direktno preko solarnih panela bez korištenja akumulatora. Ovako izgleda taj moj projekat a da li neko zna kako bih mogao usavršiti ovaj moj sistem da ga koristim direktno sa strujom koja dolazi sa solarnih panela bez korištenja akumulatora?. Da li da ceo sistem povežem nekako drugačije ili mi treba još neka druga komponenta da bi sve još bolje radilo?.
Ako imamo 275w max snagu panela, na 36v to je oko 7,6A na 36v. Buster dize voltazu, ali smanjuje amperazu, i orjentirno, ako ne grijesim dizanje za 3x voltaze, smanjuje amperazu za 3x, mozda i vise zbog gubitaka, jer da nije toga perpetum mobile bi bilo jako lako napraviti.
. I sad ako se ubaci inverter da pretvori to na 220v onda su gubici toliki da se jako malo struje moze iskoristiti.
Kad bi moglo da se sa 275w i 36 v nekako invertuje na 275w i 220v, bez gubitaka to bi bio pronalazak za nobelovi nagradu.
Ali i dalje ne kontam kako trimer radi na dc struju.
A motor sto ne bi radio? Njemu sve jedno da li je DC ili AC. To su univerzalni motori sa cetkicama, kao kod busilice, usisivaca, miksera, novijih ves masina...
Oni imaju elektromagnet za stator i rotor. Pa mu je sve jedno sta je na ulazu. I obicno je potreban dosta manji DC napon, jer struju ogranicava otpor zice, i indukovana EMS u rotoru. A u slicaju naizmenickog imas i induktivnost svih kalemova.
Sto je ovde i slucaj.
I jos bitna stvar, trimer nema elektroniku za regulaciju brzine, nego samo prekidac...
Regulacija brzine ne voli DC. Busilica bi se verovatno ukljucila na max, i ne bi se iskljucila dok ne iscupas kabal.
BOSSKE, negde sam video post da te muci ves masina, jesi to resio?
Nisam rijesio masinu, dao sam nekom elektronicaru da je proba i kaze da je crko procesor na ploci, a nova ploca preko 100e, tako da ce ici u reciklazu
Ovi stepup su puno efikasniji od dc/ac invertera. Tako da dva spojena ovako na red je prilicno efikasno. Ali opet glavni nedostatak je pracenje snage sa panela.
I jos fali zastita na izlazu itd. Ali to je druga prica...
