Centrometal Peltec 48kw P...
Subvencije za stolariju,...
Održavanje hidromasažne kade
2 poruka / 0 new
Sun, 03/01/2010 - 23:12
Jale
Jale's picture
Registrovan dana: 03/01/2010
Kako izbeći gomilanje crnih naslaga (verovatno gljivica) u prskalicama?
  • 4207 prikaza
  • Kupatilo
Tue, 05/01/2010 - 13:11
Re: Održavanje hidromasažne kade
jasna
jasna's picture
Registrovan dana: 13/06/2008
Prati dezinfekcionim rastvorom?
Kad izguglas, dobijes:
Da biste vašu kadu održavali higijenski čistom (ukoliko nemate ugrađen sistem za dezinfekciju) preporučujemo vam naš dezinfekcioni rastvor koji se lako primenjuje: po mogućnosti nakon svakog kupanja, ali bar jednom mesečno sipati jedan do dva zatvarača (u zavisnosti od veličine kade) dezinfekcionog sredstva u kadu napunjenu čistom vodom i uključite sistem cca. 10min. Tada ispraznite kadu i sperite je čistom vodom pre sledeće upotrebe.
Whirlpool Maintenance: It is recommended that the circulation system be cleaned once every 2-3 weeks. There are several whirlpool tub cleaners available on the market. If a cleaner is not available, fill the tub with warm water, add 1 teaspoon of a mild dishwashing liquid and ½ cup bleach. Run the whirlpool system for several minutes. Drain and fill with cold water. Run the whirlpool system for five minutes. Drain.
Air Tub Maintenance: Air baths are equipped with an automatic blow drying function to eliminate excessive moisture from the channels after they shut off. This purges the system of all moisture.
