OBOD HOZ-340.310 zamrzivac sema
2 poruka / 0 new
Piotr
Piotr's picture
Registrovan dana: 25/03/2019
Hello,
I have chest freezer OBOD LUX, model HOZ-340.310, produced in 1990 and still brand new...
When I turned it on the compressor worked properly, but it didn't freezing (temperature was not lower). It occured that there are some disconnected cables (see enclosed picture).
Could you please advise how to connect them or send an electrical wiring diagram?
Thank you in advance for assistance.
Best wishes from Poland,
Piotr
Vukoje.B
Vukoje.B's picture
Registrovan dana: 13/11/2009
I couldn't find the wiring diagram, but there are functions of switches/indicators.
Maybe it help You to connect cables properly:
- green - POWER ON - always ON when freezer is properly plugged into wall plug.
- red - WRONG TEMP - ON when set temperature not reached.
- yellow - FORCED ON - compressor is working until that switch is OFF.
But, according to your description, it smells to me like system is out of freon (or whatever cooling medium is), or compression fault.
If compressor is working properly, there must be some temperature changes inside.
Ništa ne ostavljam nezavrš
