http://rapidshare.com/files/198120926/159.DIY.rar
svi u pdf-ovima,velicina 20687 KB
* 30 Quick Fixes For Everyday Disasters.pdf
* 4x8 Utility Trailer-Drawings.pdf
* 4x8 Utility Trailer-Instructions.pdf
* A Guide To Building Outdoor Stairs.pdf
* About Bathrooms.pdf
* About Kitchens.pdf
* About Pvc Windows.pdf
* Actions To Prevent Flooding Around The House.pdf
* Add A Radiator.pdf
* Add A Wall Light.pdf
* Adding A Socket.pdf
* Air Bricks.pdf
* All About Decking.pdf
* Artex And Plaster.pdf
* Backyard Pond.pdf
* Basic Plumbing.pdf
* Bonus Utility Trailer Plan !.pdf
* Boxing In Pipes.pdf
* Brick Bonds.pdf
* Bricklayers Tool Kit.pdf
* Brickwork.pdf
* Build A Brick Barbecue.pdf
* Build A Carport.pdf
* Build A Shed.pdf
* Build A Shower Cubicle.pdf
* Building A Basic Cupboard.pdf
* Building A Dry Stone Wall.pdf
* Building Regulations Electrical Safety Jan 2005.pdf
* Building Traditional Casing For New Windows.pdf
* Built In Storage Space.pdf
* Cement & Mixes.pdf
* Ceramic Tiles For Worktops.pdf
* Change A Door Handle.pdf
* Changing Taps.pdf
* Cladding.pdf
* Closing And Opening An Existing Fireplace.pdf
* Colour Combinations.pdf
* Colour Schemes.pdf
* Consumer Unit.pdf
* Cornices And Coving.pdf
* Corrugated Sheet Roofing.pdf
* Create A Town Garden And Patio.pdf
* Curing An Air Lock In A Hot Water Pipe.pdf
* Deck Marking.pdf
* Deck Post Holes.pdf
* Deck Structural Design.pdf
* Decking Steps.pdf
* Design,plan & Fit A Kitchen.pdf
* Designing Your Garden.pdf
* Different Types Of Hammers.pdf
* Diy Q&A.pdf
* Dormer Building.pdf
* Dry Rot & Wet Rot.pdf
* Earth Bonding.pdf
* Electrical Safety.pdf
* Fireplace.pdf
* Fit A Bath And Wash Basin.pdf
* Fit a Toilet and Bidet.pdf
* Fit Extra Electrical Sockets.pdf
* Fitting A Mortice Latch.pdf
* Fixing To Lathe & Plaster.pdf
* Fixing To Plasterboard And Plasterboard Fixings.pdf
* Foundations For Light Garden Walls.pdf
* Garage Floor Insulation.pdf
* General Do It Yourself Safety Comments.pdf
* Gun Applied Sealants And Adhesives.pdf
* Handrail Anatomy.pdf
* Hanging A Door.pdf
* Hanging Wallpaper.pdf
* Heat Guns.pdf
* Home Security.pdf
* How A Lighting Circuit Works.pdf
* How To Avoid The Cowboy Builder.pdf
* How To Build A Deck.pdf
* How To Build A Raised Formal Pool.pdf
* How To Build A Retaining Wall.pdf
* How To Construct A Suimple Garden Pond.pdf
* How To Hang Wallpaper.pdf
* How To Install Pvc Downpipes.pdf
* How To Repair Faucets(Taps).pdf
* How To Wire A Plug.pdf
* Indoor Lighting.pdf
* In-Ground Pool.pdf
* Install A Fireplace.pdf
* Install An Electric Shower.pdf
* Install Guttering.pdf
* Installing A Peephole.pdf
* Installing A Pre-Hung Door.pdf
* Installing Deck Boards.pdf
* Installing Deck Joists.pdf
* Installing Deck Posts.pdf
* Installing Deck Stairs.pdf
* Installing The Deck Ledger.pdf
* Installing The Deck Railing.pdf
* Interior Painting.pdf
* Ladders.pdf
* Laminate Flooring.pdf
* Lay A Laminate Floor.pdf
* Lay A Pebble Path.pdf
* Lay Carpet Tiles.pdf
* Lay Paving Stones.pdf
* Laying A Brick Walkway Or Patio.pdf
* Laying A Deck Straight.pdf
* Laying Stepping Stones.pdf
* Lining Paper.pdf
* Man-Made Board.pdf
* Matching Sand And Cement Mixes.pdf
* Measuring And Marking.pdf
* Metric And Imperial Conversions.pdf
* Nails.pdf
* Outdoor Lighting.pdf
* Paint Effects.pdf
* Painting A Ceiling.pdf
* Painting A Door.pdf
* Painting Ceramic Tiles.pdf
* Painting Interior Panel Doors.pdf
* Painting Interior Walls.pdf
* Painting Problems.pdf
* Painting Tips & Secrets.pdf
* Pests Around The House.pdf
* Planning A Deck.pdf
* Planning A New Internal Partition.pdf
* Planning Permission And Building Regulations.pdf
* Plumbing Care And Repair.pdf
* Pointing Brickwork.pdf
* Producing Drawings For Planning Permission.pdf
* Pvc And Polycarbonate Roofing.pdf
* Radial Circuit.pdf
* Remove A Radiator.pdf
* Removing Or Plastering Over Artex.pdf
* Renovating Wood.pdf
* Repairing A Dripping Tap.pdf
* Replace Broken Tiles.pdf
* Replacing A Brick.pdf
* Safe Diy.pdf
* Sandpapers No2.pdf
* Shelving And Storage.pdf
* Size Conversion Charts.pdf
* Spanners And Wrenches.pdf
* Sticky Door.pdf
* Sunshine Ceiling(1).pdf
* Sunshine Ceiling(2).pdf
* Three Layer Felt Roofing.pdf
* Timber Care.pdf
* Timber Cutting Hand Saws.pdf
* Timber Decking.pdf
* Tow Dolly Plans.pdf
* Towing Dolly Instructions.pdf
* Upvc Fascia.pdf
* Wainscotting.pdf
* Wall Fixings For Hollow & Solid Surfaces.pdf
* Wall Tiling.pdf
* Wallpaper A Ceiling.pdf
* Wallpaper Stripping.pdf
* Wallpapering Techniques.pdf
* Waterproof Your Roof.pdf
* Wiring A Junction Box.pdf
* Wiring A Ring Main.pdf
* Wooden Interior Doors.pdf
And many more...
i kako vam se svidja ?
