Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13)
query: INSERT INTO watchdog
(uid, type, message, variables, severity, link, location, referer, hostname, timestamp)
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:8513d01fb50a047539c8f292c44cb434'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/usteda-elektricne-energije', '', '172.70.130.247', 1748723346) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:1212:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Pitanje koje verovatno muci vecinu u zimskom periodu narocito one koji se greju na struju je kako ustedeti, koji je nacin grejanja najjevtiniji najefikasniji i najkonforniji?<br />\\nGrejem kucu od 120m2 na dva nivoa 60+60m2 veliki potrosaci su 4 TA peci(15KW) i jedna panelna grejalica, dva bojlera od po 80l i jedan od 10l, sporet, frizider, friz i osvetljenje</p>\\n<p>Buduci da se grejem sa TA pecima i da mi je za prosli m in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:ab0ddf43956afcc1ee5099c08d759849'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/usteda-elektricne-energije', '', '172.70.130.247', 1748723346) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:740:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Samo jedna mala digresija, neka dobro svi pogledaju svoje racune ovog meseca i uocice da je povecanje od 100% maltene svima uracunato, iako niti su se vise grejali niti je bilo zvanicnog povecanja cene struje! Sve mi se cini da su morali nekako da namire strajkace, pa su odokativnom metodom podigli svima racune!</p>\\n<p>E sad, postavlja se pitanje, kome se zaliti u slucaju da sumnjate u verodostojnost racuna i kako to dokazati?!</ in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:0d621542e71d08efc63f924e64c0dbee'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/usteda-elektricne-energije', '', '172.70.130.247', 1748723346) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:341:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Ako kaniš pobijediti, ne smiješ izgubiti!!!</p>\\n ', created = 1748723346, expire = 1748809746, headers = '', serialized = 0 WHERE cid = '1:0d621542e71d08efc63f924e64c0dbee'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:108;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/u in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:9b33e17e8f51b9cff48ac6bd49c764ec'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/usteda-elektricne-energije', '', '172.70.130.247', 1748723346) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:358:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Zali se upravi vodovoda(za racun za struju)ha-ha :hh :hh :hh</p>\\n ', created = 1748723346, expire = 1748809746, headers = '', serialized = 0 WHERE cid = '3:9b33e17e8f51b9cff48ac6bd49c764ec'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:108;}', 3, '', 'http://www.samsvojmajstor.co in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:8e0594b8236a6c9098fc3eab239df16e'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/usteda-elektricne-energije', '', '172.70.130.247', 1748723346) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:354:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>ve-ka majstor - popravlja sve osim karaktera, nema delova!</p>\\n ', created = 1748723346, expire = 1748809746, headers = '', serialized = 0 WHERE cid = '1:8e0594b8236a6c9098fc3eab239df16e'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:108;}', 3, '', 'http://www.samsvojmajstor.com/po in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:7d356ab531042249cb367847f0bde9a9'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/usteda-elektricne-energije', '', '172.70.130.247', 1748723346) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:587:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Ve-ka majstor, popravlja sve osim karaktera-nema delova(Ve-ka nije kvalifikacija nego skraćeno ime)<br />\\n<a href=\\"https://www.facebook.com/cepacizadrva1/\\" title=\\"https://www.facebook.com/cepacizadrva1/\\">https://www.facebook.com/cepacizadrva1/</a></p>\\n ', created = 1748723346, expire = 1748809746, headers = '', serialized = 0 WHERE cid in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:940e5c108476bd4864077d9ed8ea913d'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/usteda-elektricne-energije', '', '172.70.130.247', 1748723346) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:417:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Uleteo si debelo u crveno i zato ti se dupliro račun.<br />\\nPromeni način grejanja ili ubaci još jedno brojilo.</p>\\n ', created = 1748723346, expire = 1748809746, headers = '', serialized = 0 WHERE cid = '3:940e5c108476bd4864077d9ed8ea913d'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\" in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:3a1b4c25e6a63ddf7f62407f83d3ae12'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/usteda-elektricne-energije', '', '172.70.130.247', 1748723346) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:309:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Pozdrav Laki.</p>\\n ', created = 1748723346, expire = 1748809746, headers = '', serialized = 0 WHERE cid = '3:3a1b4c25e6a63ddf7f62407f83d3ae12'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:108;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/usteda-elektricne in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:cf8c0815325777f237492ca2cdd5ca35'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/usteda-elektricne-energije', '', '172.70.130.247', 1748723346) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:627:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Hvala na odgovorima</p>\\n<p>Tajmerski uredjaji postoje na svim velikim potrosacima (TA peci, bojleri) i rade iskljucivo po jevtinoj struji u periodu od 01-07h </p>\\n<p>Da li je moguce da MTK ukljucuje jevtinu tarifu u nekom drugom periodu recimo od 02-10h pa da iz tog razloga trosim struju po skupoj tarifi</p>\\n ', created = 1748723346, expire = 1748809746, headers = ' in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:9fd67133dff1becb95a0da73c515da5a'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/usteda-elektricne-energije', '', '172.70.130.247', 1748723346) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:486:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Kažiprst! Najstariji merni instrument.Meri brzinu,temperaturu, vlažnost, dubinu, širinu,visinu,<br />\\nzapreminu, struju, napon, otpor, tvrdoću, gustinu, viskoznost, pH vrednost...</p>\\n ', created = 1748723346, expire = 1748809746, headers = '', serialized = 0 WHERE cid = '1:9fd67133dff1becb95a0da73c515da5a'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.co in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:1624ba900e0b5985398e8952f4dcc1b2'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/usteda-elektricne-energije', '', '172.70.130.247', 1748723346) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:595:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Moguće je da brljavi ako je staro brojilo pa je oslabila baterija i ne prebacuje kad treba a možda ovi iz EPS-a uključe kad im dune.....to možeš jedino da proveriš tako što ćeš odeš do brojila i da pogledaš gde okrenuta strelica.....<br />\\npar dana nasumice izabranih u mesecu.....</p>\\n ', created = 1748723346, expire = 1748809746, headers = '', serialized = 0 WHERE cid = '3:1624ba900e0b59 in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:bef78739409cfdf198fd2199ee831759'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/usteda-elektricne-energije', '', '172.70.130.247', 1748723346) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:445:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>A ko odredjuje kad jeftina a kad skupa<br />\\nMTK automatski ili EPS salje signal na MTK</p>\\n<p>I brojilo i MTK su iz 70-ih godina</p>\\n ', created = 1748723346, expire = 1748809746, headers = '', serialized = 0 WHERE cid = '3:bef78739409cfdf198fd2199ee831759'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/inc in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
VALUES
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:1b976be534eb36ca0431192c9a92253a'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/usteda-elektricne-energije', '', '172.70.130.247', 1748723346) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:971:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>EPS šalje signal....<br />\\nDa ne širim priču, trebalo bi da uskoro urade zamenu brojila na nivou cele zemlje tako da je savet da sačekaš tu zamenu.Ne znam da li si potpiso ugovor da im pokloniš to staro brojilo a ne bi bilo loše da se raspitaš koliki bi bili troškovi za uvođenje još jednog brojila ali mislim da bi ti se isplatilo za dve grejne sezone...<br />\\nRaspitaj se kakva je mogućnost uvođenja treće tarife.....& in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:5a3dfebf2b7bc54ec8903126c8645567'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/usteda-elektricne-energije', '', '172.70.130.247', 1748723346) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:924:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Kao sto sam i mogao da pretpostavim, dosao mi je racun duplo veci nego prosli mesec iako, koliko se secam, bilo je dosta toplih dana kada se i nije bas stan grejao. </p>\\n<p>Da li je moguce da jedan radijator od 2kw i dva od 1.5kw + standradni potrosaci(bojler, sporet, tv, komp) mogu da potrose struje u iznosu od 8000din? :nono :tup :tup </p>\\n<p>Neko tu nekoga farba a ja sebi sve vise licim na indijanca : in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
VALUES
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:e185d308a5f3face65911f6652484727'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/usteda-elektricne-energije', '', '172.70.130.247', 1748723346) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:1099:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Koliko god da se trudio da prokljuvim racun ne ide mi. Cak mi se cini da sto vise stedim struju racun mi je sve veci.</p>\\n<p>Moguce je da je racun veci zbog novogodisnjeg raspusta vecina je sedela kod kuce u periodu od 30.12 do 11.01 i tada smo se intenzivnije grejali kuvali i trosili struju preko dana. Ali duplo veci mi je sumnjivo.</p>\\n<p>Mislim da je pametnije da umesto radijatora uzmes TA peci posto ra in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
VALUES
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:cd617b715531558284457d1276b7d78f'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/usteda-elektricne-energije', '', '172.70.130.247', 1748723346) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:1045:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Da li periodično kontrolišete brojilo, ili se samo zapanjite kad stigne račun ? Pošto se i ja grejem na struju, obavezno kontrolišem stanje brojila jednom nedeljno. </p>\\n<p>Računica je neverovatno prosta: na poslednjem računu za struju piše kog datuma je čitano brojilo, i koje je stanje brojača. Jednom nedeljno očitam brojilo, oduzmem od trenutnog stanja brojača ono stanje po kom je fakturisan poslednji račun (posebno za s in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:3d57d580638b6ab2348db89f47054b67'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/usteda-elektricne-energije', '', '172.70.130.247', 1748723346) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:343:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Nema glupih pitanja. Ima samo glupih odgovora !</p>\\n ', created = 1748723346, expire = 1748809746, headers = '', serialized = 0 WHERE cid = '1:3d57d580638b6ab2348db89f47054b67'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:108;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:e3f6103330cb96a9985fd2aed2ba7513'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/usteda-elektricne-energije', '', '172.70.130.247', 1748723346) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:585:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Zar jeftina struja nije <a href=\\"http://www.edb.co.yu/glavna.htm\\" class=\\"bb-url\\">od ponoći do 8 ujutro </a> ? U vrhu iste strane postoji <span style=\\"color:red\\">Kalkulator potrošnje</span> , njime se može sračunati iznos....</p>\\n ', created = 1748723346, expire = 1748809746, headers = '', serialized in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:1264fbf58ddeb4f99260085babba514f'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/usteda-elektricne-energije', '', '172.70.130.247', 1748723346) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:1842:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Ovo postaje sve gore i gore :tup :tup :tup </p>\\n<p>Sad mi je stigao racun 11000 dinara i potrosenih 1789kwh za 27 dana(12.01.2010-08.02.2010). To znaci da sam usao u crvenu tarifu, tj da sam trosio preko 53,3kwh dnevno 8-O 8-O 8-O </p>\\n<p>Voleo bih da mi neko objasni kako sam to uspeo, ako od 8 do 17h nisam kuci, a kad se vratim rade dva radijatora, jedan od 2kwh i jedan od 1,5kwh, bojler je non-stop in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
VALUES
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:cd2f0c8cf613fc2ce7a6bda77f388a17'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/usteda-elektricne-energije', '', '172.70.130.247', 1748723346) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:682:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Ajde napiši koliko piše da si potrošio više a koliko niže tarife, koje sve el.uredjaje(koje snage) imaš po kući i koliko vremena rade dnevno....pa da napravimo neku matematiku..... <img src=\\"http://www.samsvojmajstor.com/portal/sites/all/modules/smileys/packs/Roving/wink.png\\" title=\\"Wink\\" alt=\\"Wink\\" class=\\"smiley-content\\"/></p>\\n ', cr in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:99d2a454b7cbad610a3f68de36fb3112'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/usteda-elektricne-energije', '', '172.70.130.247', 1748723346) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:1550:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Grejem 120kvm samo na struju i svuda je toplo</p>\\n<p>Potrosaci:<br />\\nTA pec 4,5kw 2 komada, TA pec 3kw 2 komada, grejalica 1,kw, bojler kupatilski 80 lit 2 komada, bojler kuhinjski 10 lit, sporet, TV, komp, muzika, ves masina, ostali \\"mali\\" potrosaci i 41 sijalicno mesto (brojao pre neki dan zbog kupovine stedljivih sijalica).</p>\\n<p>racun za januar (12.01.2010-04.02. in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
VALUES
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:f488dd20be197714bfa8e2fda78c80d0'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/usteda-elektricne-energije', '', '172.70.130.247', 1748723346) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:1189:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p><div class=\\"bb-quote\\"><b>clockwork_orange wrote:</b><blockquote class=\\"bb-quote-body\\">Pitanje koje verovatno muci vecinu u zimskom periodu narocito one koji se greju na struju je kako ustedeti, koji je nacin grejanja najjevtiniji najefikasniji i najkonforniji?<br />\\n....</blockquote></div></p>\\n<p& in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:afb6e5c17bc436b373cdd0ce479f22f3'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/usteda-elektricne-energije', '', '172.70.130.247', 1748723346) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:1308:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p><div class=\\"bb-quote\\"><b>djuma wrote:</b><blockquote class=\\"bb-quote-body\\"> </blockquote></div></p>\\n<p>Da li je moguce da jedan radijator od 2kw i dva od 1.5kw + standradni potrosaci(bojler, sporet, tv, komp) mogu da potrose struje u iznosu od 8000din? :nono :tup :tup<br />\\n</p> in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:65115f119d25e3805f644d9f7bb8cb91'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/usteda-elektricne-energije', '', '172.70.130.247', 1748723346) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:1234:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Potrosaci:<br />\\nTri radijatora, jedan od 2kwh i dva od 1.5kwh(s tim sto je jedan od ova dva u kupatilu pa se koristi samo 15 min dnevno, tj dok se tusiram), bojler (mislim da je 2kwh), protocni bojler (takodje mislim da je 2kwh), kompjuter, televizor, sporet, sijalice...</p>\\n<p>Racun za januar (12.01.2010-08.02.2010) bez TV pretplate 10,637 dinara</p>\\n<p>zelena<br />\\nVT 212 in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
VALUES
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:a587067eec58dc682789cdf903b6e30e'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/usteda-elektricne-energije', '', '172.70.130.247', 1748723346) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:1103:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p><div class=\\"bb-quote\\"><b>clockwork_orange wrote:</b><blockquote class=\\"bb-quote-body\\">Postavih pitanje u drugoj temi koja je zakljucana pre nego sto dobih odgovor,<br />\\nKoliko stedljive sijalice stvarno trose struje da li su stvarno stedljive ili je marketinski trik u pitanju. rado bi ih kupio ako su stvarno stedljiva ipak 41 sijalica po 300 dinara n in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:6af11a34491e00f0a650046715b99532'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/usteda-elektricne-energije', '', '172.70.130.247', 1748723346) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:2680:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p><div class=\\"bb-quote\\"><b>clockwork_orange wrote:</b><blockquote class=\\"bb-quote-body\\">Grejem 120kvm samo na struju i svuda je toplo</blockquote></div></p>\\n<p>,<br />\\nKoliko stedljive sijalice stvarno trose struje da li su stvarno stedljive ili je marketinski trik u pitanju. rado bi ih kupio ako in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:f5c167882af7d6d080ee9f808bce6274'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/usteda-elektricne-energije', '', '172.70.130.247', 1748723346) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:1210:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p><div class=\\"bb-quote\\"><b>djuma wrote:</b><blockquote class=\\"bb-quote-body\\">A da zaboravih da kazem da stan ima samo 46m2 :tup :tup :tup izolacija je odlicna jer je stara zgrada gde su zidovi debeli po 50cm(puna cigla) + menjao sam kompletnu stolariju prilikom useljenja</blockquote></div></p>\\n<p>Ne bih da st in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:92b8bba8a4e004092c9fe5212e995697'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/usteda-elektricne-energije', '', '172.70.130.247', 1748723346) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:603:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Ok, prihvatam tvoj stav, ali mozemo li se vratiti na potrosnju elektricne energije i kude mi se dede moj novac bato??!! 8-O 8-O 8-O </p>\\n<p>11000din za 46m2 za 27dana??? Pa da li je to normalno???</p>\\n<p>Pogledaj potrosace od clockwork_oranga, a njemu manji racun, pa kako to???</p>\\n ', created = 1748723346, expire = 1748809746, headers = '', serialized = 0 WHERE in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
VALUES
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:a80f35a2fc0722949758e2cbefdf3764'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/usteda-elektricne-energije', '', '172.70.130.247', 1748723346) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:418:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>bolje da neznaš kolki je meni bio račun za gas za januar ni neznaš kolko si sretan<br />\\n :roll: :roll: :roll:</p>\\n ', created = 1748723346, expire = 1748809746, headers = '', serialized = 0 WHERE cid = '3:a80f35a2fc0722949758e2cbefdf3764'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\&quo in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:cc8449f0c8a177a82b0ffe341bbb6963'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/usteda-elektricne-energije', '', '172.70.130.247', 1748723346) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:628:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p><a href=\\"http://kreativnost.4umer.com/\\" title=\\"http://kreativnost.4umer.com/\\">http://kreativnost.4umer.com/</a><br />\\n<a href=\\"http://perinedrangulije.multiply.com/\\" title=\\"http://perinedrangulije.multiply.com/\\">http://perinedrangulije.multiply.com/</a></p>\\n ', created = 1748723346, e in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:beab41f23fdcfd6225f2c361489aa1be'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/usteda-elektricne-energije', '', '172.70.130.247', 1748723346) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:601:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p><a href=\\"http://peradetlic.hupont.hu/\\" title=\\"http://peradetlic.hupont.hu/\\">http://peradetlic.hupont.hu/</a><br />\\n<a href=\\"http://kreativnost.4umer.com/\\" title=\\"http://kreativnost.4umer.com/\\">http://kreativnost.4umer.com/</a></p>\\n ', created = 1748723346, expire = 1748809746, headers in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:349453a90a9dc5af83286e65816b0705'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/usteda-elektricne-energije', '', '172.70.130.247', 1748723346) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:1435:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p><div class=\\"bb-quote\\"><b>djuma wrote:</b><blockquote class=\\"bb-quote-body\\">Ok, prihvatam tvoj stav, ali mozemo li se vratiti na potrosnju elektricne energije i kude mi se dede moj novac bato??!! 8-O 8-O 8-O </blockquote></div></p>\\n<p>11000din za 46m2 za 27dana??? Pa da li je to normalno???</p> in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:159394773b91ec93222bebc269bfecef'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/usteda-elektricne-energije', '', '172.70.130.247', 1748723346) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:1112:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p><div class=\\"bb-quote\\"><b>milisav68 wrote:</b><blockquote class=\\"bb-quote-body\\">Nisi napisao koliko sati dnevno ti rade radijatori.....i na koju si temperaturu stavio termostat.</blockquote></div><br />\\nPa da kazem da kad je bilo hladno da su radili od 17h do 8-9 ujutru :tup<br />\\nNaravno, ne svaki dan, ali u in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
VALUES
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:e42a117142470221ffb9be24c71bd87e'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/usteda-elektricne-energije', '', '172.70.130.247', 1748723346) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:1401:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p><div class=\\"bb-quote\\"><b>djuma wrote:</b><blockquote class=\\"bb-quote-body\\"> Sto se tice termostata on je izbazdaren od 1-9, al tek od 5 ima efekta, tako da nikad nije bio ispod. Samo nije mi jasno u cemu je razlika da li je na 7,8 ili 9, kad cim se ukljuci, makar radio i na 1, trosi 2kw/h?!</blockquote></div><br />\\nRazlika in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:db2e38ff7812c38882d2133891eb32c1'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/usteda-elektricne-energije', '', '172.70.130.247', 1748723346) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:308:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Pozdrav laki</p>\\n ', created = 1748723346, expire = 1748809746, headers = '', serialized = 0 WHERE cid = '3:db2e38ff7812c38882d2133891eb32c1'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:108;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/usteda-elektricne- in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:8784b1cb3e50484521ee828401bfa9fb'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/usteda-elektricne-energije', '', '172.70.130.247', 1748723346) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:1241:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Sta cu, kad u skoli nisam bio odlikas, bar kod svoje kuce sebi da udovoljim :hh :hh :hh al to izgleda kosta :tup </p>\\n<p>Nema sta da proveravam, imam tu lampicu i sad kad malo bolje razmislim totalno je logicno <img src=\\"http://www.samsvojmajstor.com/portal/sites/all/modules/smileys/packs/Roving/wink.png\\" title=\\"Wink\\" alt=\\"Wink\\" class=\\"smiley-conte in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
VALUES
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:1ca53eebd469d0848119e54c0b4c3c9d'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/usteda-elektricne-energije', '', '172.70.130.247', 1748723346) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:348:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Nemoj, osim ako imaš para za bacanje. :hh :hh :hh</p>\\n ', created = 1748723346, expire = 1748809746, headers = '', serialized = 0 WHERE cid = '3:1ca53eebd469d0848119e54c0b4c3c9d'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:108;}', 3, '', 'http://www.samsvojmajstor.com/portal/f in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:f13ab5fd65e4c7bb161cc424ccd09e7a'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/usteda-elektricne-energije', '', '172.70.130.247', 1748723346) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:837:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p><div class=\\"bb-quote\\"><b>djuma wrote:</b><blockquote class=\\"bb-quote-body\\"><div class=\\"bb-quote\\"><b>milisav68 wrote:</b><blockquote class=\\"bb-quote-body\\"></blockquote></div></blockquote></div></p>\\n& in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
VALUES
VALUES
VALUES
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '2:abfecc63f09f063c306e2753273f32e4'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/usteda-elektricne-energije', '', '172.70.130.247', 1748723346) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:942:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = '<p><iframe id=\\'a431a3a0\\' name=\\'a431a3a0\\' src=\\'https://adserver.samsvojmajstor.com/adserver/www/delivery/afr.php?zoneid=26&amp;cb=9900435235423422\\' frameborder=\\'0\\' scrolling=\\'no\\' width=\\'728\\' height=\\'90\\'><a href=https://adserver.samsvojmajstor.com/adserver/www/delivery/ck.php?n=afcbc006&amp;cb=9900435235423422\\� in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '2:ca011fdebe3a51dea5859d4aba19f564'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/usteda-elektricne-energije', '', '172.70.130.247', 1748723346) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:956:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = '<p><iframe id=\\'a354bc39\\' name=\\'a354bc39\\' src=\\'https://adserver.samsvojmajstor.com/adserver/www/delivery/afr.php?zoneid=27&amp;cb=002874370149734552\\' frameborder=\\'0\\' scrolling=\\'no\\' width=\\'234\\' height=\\'160\\'><a href=\\'https://adserver.samsvojmajstor.com/adserver/www/delivery/ck.php?n=aa83fdd3&amp;cb=0028743701 in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '2:64a277481435f3c6a7b18eb6fa57f957'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/usteda-elektricne-energije', '', '172.70.130.247', 1748723346) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:868:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = '<p><iframe id=\\'a694a55c\\' name=\\'a694a55c\\' src=\\'https://nepremicnine.click/www/delivery/afr.php?zoneid=99&amp;cb=43241234\\' frameborder=\\'0\\' scrolling=\\'no\\' width=\\'300\\' height=\\'600\\'><a href=\\'https://nepremicnine.click/www/delivery/ck.php?n=a9f8f8a5&amp;cb=63456\\' target=\\'_blank\\'& in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135 Usteda elektricne energije | www.samsvojmajstor.com
Buduci da se grejem sa TA pecima i da mi je za prosli mesec stigao dupliran racun opet se otvorilo pitanje kako ustedeti struju pogotovo preko dana to jest smanjiti potrosnju skupe struje.
TA peci rade izmedju 01-07h
Bojleri izmedju 05-07h
Sporet na plin(dve ringle)
Obicno je racun oko 7.500 ali poslednji racun je stigao 15.000
Za grejanje sam porosio 4.500 (jevtina struja)
Izlazi da 10.000 potroseno na osvetljenje, TV, frizider....
Neko tu nekoga farba a ja sebi sve vise licim na indijanca :tup
I da iskoristim priliku da pitam, da li vi vas bojler drzite non-stop ukljucenim ili ga palite samo po potrebi i kolika moze biti razlika u ceni od slucaja do slucaja?
Mislim da je pametnije da umesto radijatora uzmes TA peci posto radijatori rade samo u periodu kad je skupa struja dok se TA peci pune po jevtinoj tarifi koja je 4 puta jevtinija.
Kao sto rekoh bojleri su mi na tajmerskim uredjajima i oni rade u periodu od 05-07 (jevtina struja) i voda u njima ostane dovoljno topla do uvece. Da li u tom rezimu trose vise ili manje struje ne znam ali znam da trose jevtinu struju
Računica je neverovatno prosta: na poslednjem računu za struju piše kog datuma je čitano brojilo, i koje je stanje brojača. Jednom nedeljno očitam brojilo, oduzmem od trenutnog stanja brojača ono stanje po kom je fakturisan poslednji račun (posebno za skupu, posebno za jeftinu struju) i tako, jednostavno znam koliko sam potrošio. Na nekoliko domaćih sajtova ima kalkulator potrošnje, i tako znam i koliko para treba da spremim.
Naravno leti ne očitavam brojilo, jer je i potrošnja i račun tek deseti deo zimske potrošnje.
Voleo bih da mi neko objasni kako sam to uspeo, ako od 8 do 17h nisam kuci, a kad se vratim rade dva radijatora, jedan od 2kwh i jedan od 1,5kwh, bojler je non-stop ukljucen(mada mi ovi iz elektrodistribucije kazu da bi trebalo da ga iskljucujem i da cu tako da smanjim potrosnju), kompjuter, TV i mozda povremeno ringla (ako se nesto podgreva, retko kuvam)?!
Zvao sam i EDB i covek mi kaze da postoje 3 mogucnosti:
1. Da sam stvarno toliko potrosio
2. Da lose radi brojilo
3. Da se neko prikljucio na moje brojilo
Odlucio sam se da probam prvo ovo pod 2, tj da odem da podnesem zahtev u EDB za bazdarenje brojila, to je 770din i to placate samo ako se ustanovi da niste u pravu. Ako ste u pravu, imate pravo na reklamaciju, ali onda verovatno tek krecu peripetije, tj kako retroaktivno da mi vrate pare ili izmere struju, pa ce uzimati neki raniji period. Uhhh, da vas ne smaram vise, pisacu kad budem imao jos nekih informacija a do tada bih voleo da cujem i vase misljenje
Potrosaci:
TA pec 4,5kw 2 komada, TA pec 3kw 2 komada, grejalica 1,kw, bojler kupatilski 80 lit 2 komada, bojler kuhinjski 10 lit, sporet, TV, komp, muzika, ves masina, ostali "mali" potrosaci i 41 sijalicno mesto (brojao pre neki dan zbog kupovine stedljivih sijalica).
racun za januar (12.01.2010-04.02.2010) sa Tv pretplatom 10,711 dinara
zelena
VT 76kw 299 din
MT 192kw 189 din
plava
VT 272kw 1605 din
MT 686kw 1012 din
crvena
VT 306kw 3613 din
MT 774kw 2284 din
Ukupno portoseno 2306KW od toga skupe struje 654kw i jeftine 1652kw
I ja bi voleo da znam na koji nacin mogu da smanjim potrosnju to jest racun
P.S.
Koliko stedljive sijalice stvarno trose struje da li su stvarno stedljive ili je marketinski trik u pitanju. rado bi ih kupio ako su stvarno stedljiva ipak 41 sijalica po 300 dinara nije mala investicija
Najefikasniji, najkomforniji, najjeftiniji ...je termicka izolacija zgrade i umanjenje ventilacionih gubitaka.
Pouzdano, trajno, garantovano smanjuje troskove za potrosenu energiju.
I podjednako vazi za blo kakav sistem grejanja.
Dokazano u praksi.
Iz iskustva za 300+ kvadrata grejanja, potrosena struja je bila oko 5900 dinara za decembar mesec.
Potrosena i 4 dzaka ogrevnog drveta (iz hiper marketa) od po 25kg, ukupno 100 kg.
2+1.5+1.5= 5kW samo radijatori.
neka mesecno ima 720 sati, to je 3600 kWh ako su non stop radili.
Koliko je bilo stvarno vreme rada i time potrosnja odredjeno je samom kucom/ zgradom koja je efektivni korisnik energije tj potrosac.
Radijatori su samo konverteri i (radi prakticnosti racunice da zanemarimo 0.1% moguce potrosnje samih radijatora) ne trose nista.
3600kWh (hipotetickih) kosta razlicito zavisno u kojoj od 6 tarifa su potroseni.
Tako da je odgovor da je zaista sasvim moguce da se potrose 8000 dinara.
I cak mnogo vise...
Potrosaci:
zelena
VT 212kw 834 din
MT 103kw 101 din
plava
VT 756kw 4463 din
MT 369kw 544 din
crvena
VT 235kw 2774 din
MT 114kw 336 din
Ukupno portoseno 1789KW od toga skupe struje 1203kw i jeftine 586kw
Nije marketingški trik, stvarno troše manje struje, ali mora da se obrati pažnja na proizvođača i prodavca.Drugo, ne moraš da menjaš svih 40 sijalica, za početak zameni 5 ili 10 na onim mestima gde najviše rade, pa sačekaj mesec dva, pa proveri potrošnju.Moj savet, kupi Osram sijalice jer je najbiolji odnos cena/kvalitet.
Za 120 kvadrata prosecnog objekta (tj neizolovanog) kakav je tipican kod nas i trosak grejanja je tipican, odnosno kolicina kWh.
Ja ne vidim nista cudno, otprilike to je to.
Stedljive sijalice trose ali stvarno tacno onoliko koliko i pise na njima.
Dakle, ako pise 7W onda trose7, ako pise 11W onda 11, itd.
U odnosu na klasicne sijalice sa zarnom niti, efikasnije su oko 500% tj za toliko vise struju pretvore u svetlost.
Kod obicne sijalice oko 97-98% struje sluzi za grejanje objekta kao radijator a ostatak od 2-3% je zaista svetlo.
Prema opisu koristi se povremeno i 41 mali radijator, pa puta n sati rada i eto sakupljenih bodova, pardon kWh.
Da se ne salim oko zajednicke muke cene energije, stedne sijalice (neonke) se zaista isplate a pogotovu LED sijalice koje su efikasnije od stednih sijalica jos oko 800%.
LED u odnosu na klasicno svetlo je efikasnije u konverziji struje u svetlo oko 4.000 %.
Ja sam nedavno radi probe uzeo samo jednu kombinovanu LED-stednu u istom kucistu.
Kada koristim LED trosi se 0.30 W u poredjenju sa klasicnom koja bi trosila 40W na istoj poziciji (mestu osvetljavanja, hodnik).
Do nedavno su stedne sijalice mogle da se nadju po ceni od oko 1evra za 20W model, a sada su naglo poskupile i ta ista (isti model, ista marka, ista firma) sada kosta oko 2.2 evra.
Da li ima veze sa propisima u EU ne znam, ali je razlika u ceni vise nego ocigledna.
Srecom imam zalihe, tih jeftinijih stednih. slucajnost.
Inace, mala napomena iz mog iskustva- nisu sve stedne bas iste.
Treba dobro obratiti paznju za preporucenu namenu i pre svega temperaturu boje.
Ne bih da stajem na muku, ali opisano je tipicna zgrada (starija) bez izolacije.
Ne da je odlicna, termo izolacija pune cigle je skoro pa nula po efektima.
tih 50cm je tek oko 1.5-2cm ekvivalentne termicke izolacije, da ne racunamo hiljade hladnih mostova na malteru, verovatno nadvoji, podovi, itd itd.
Ugrubo, takva tipicna zgrada trosi oko 250-300 kWh za grejanje po m2 prostora koji se greje godisnje.
Mislim da se tvoje iskustvo dosta poklapa sa tim ocekivanjima.
2KW+1,5KW=3,5KW puta recimo 8 sati dnevno puta 27 dana jednako 750KW
plus dva biojlera, nisi naveo veš mašinu,....... komp i monitor troše 1KW dnevno ako recimo rade 6 sati dnevno....
Račun koji si naveo je 9056 dinara + 18%PDV + zajednička potrošnja u zgradi od oko 150 dinara + taksa na brojilo od oko 300 dinara.....nakupi se..
Manje-više to je to.....imaš dosta skupe struje jer se greješ sa radijatorima....moj savet kupi bar jednu TA peć da bi trošio više jeftine struje koja je 4 puta manja.....
Naravno, ne svaki dan, ali u proseku oko 7-8 sati.
Hvala na pomoci, ali izgleda da meni nema pomoci :tup :tup :tup
P.S. Ostaje mi samo ovaj muceni Perica da se tesim :hh :hh :hh
Razlika je u tome što će grejač da se pali češće ako ga staviš na 9 nego na 5, pa će samim tim da se troši više struje.
Uostalom napravi "eksperiment" , stavi na 5, štopericu u ruke i slušaj koliko će puta da se čuje cak recimo za 2 sata.....a ako imaš signalnu lampicu na radijatoru, onda je još lakše jer možeš da vidiš kada ti je uključen grejač.
Nema sta da proveravam, imam tu lampicu i sad kad malo bolje razmislim totalno je logicno Hvala Milisave na savetima, al TA pec nece ulaziti kod mene, jer stan je tako sredjen da bih ga samo unakazio estetski sa TA peci. Jbga, sta da radim, kad sam rodjeni esteta :hh :hh
Znaci, na kraju da sumiram, da ipak ne podnosim reklamaciju EDB-u, tj da ne trazim zamenu i bazdarenje brojila?
Samo jedna mala digresija, neka dobro svi pogledaju svoje racune ovog meseca i uocice da je povecanje od 100% maltene svima uracunato, iako niti su se vise grejali niti je bilo zvanicnog povecanja cene struje! Sve mi se cini da su morali nekako da namire strajkace, pa su odokativnom metodom podigli svima racune!
E sad, postavlja se pitanje, kome se zaliti u slucaju da sumnjate u verodostojnost racuna i kako to dokazati?!
