Klima uredjaji - grejanje
76 poruka / 0 new
darkelja
darkelja's picture
Registrovan dana: 19/02/2009
A nijedan veze sa vezom nema.
Molim te reci mi pomocu koje formule si izracunao koliki mu je izmenjivac potreban???
Ne pitam te zbog sebe,jer ja odlicno znam te racune,nego zbog naseg nesudjenog Klimatizera,cisto da ne kopa do Kine ne bi li napravio dobar izmenjivac.
Nike
Nike's picture
Registrovan dana: 24/10/2009
Vertical
A vertical closed loop field is composed of pipes that run vertically in the ground. A hole is bored in the ground, typically 75 to 500 feet (23–150 m) deep. Pipe pairs in the hole are joined with a U-shaped cross connector at the bottom of the hole. The borehole is commonly filled with a bentonite grout surrounding the pipe to provide a thermal connection to the surrounding soil or rock to improve the heat transfer. Thermally enhanced grouts are available to improve this heat transfer. Grout also protects the ground water from contamination, and prevents artesian wells from flooding the property. Vertical loop fields are typically used when there is a limited area of land available. Bore holes are spaced at least 5–6 m apart and the depth depends on ground and building characteristics. For illustration, a detached house needing 10 kW (3 ton) of heating capacity might need three boreholes 80 to 110 m (260 to 360 ft) deep.[12] (A ton of heat is 12,000 British thermal units per hour (BTU/h) or 3.5 kilowatts.) During the cooling season, the local temperature rise in the bore field is influenced most by the moisture travel in the soil. Reliable heat transfer models have been developed through sample bore holes as well as other tests.
http://en.wikipedia.org/wiki/Geothermal_heat_pump
I dajte ljudi, drž'te se znanosti i prakse.
klimatizer
klimatizer's picture
Registrovan dana: 01/03/2009
sto rece moj kolega da su pravi majstori ne bi imali vremena od posla da pisu po forumima..al posto svi volima da pametujemo i da znamo i radimo svasta reko da podelim sa vama.
cela ova igranka mi nije problem u finansijskom smislu ( neko to vec plati jelte ) vec u cistom entuzijazmu (i mladom komsiji koji je iskopao onoliku rupu za par stotina dinkica)
da se vrnemo na poso:
Nike123 - sta mislis o klimama tj da li si video klime koje su prava ledenica i opet rade (zna COP 1:1 ili manje ) - ja to nisam dobio - jeste da su cevi bile hladne ali ne i zaledjene
zakopao sam cevi ali sam ostavio po 30 cm otkopano da bih video sta se desava oko polovine duzine ( nije zakopana skroz rupa vec nekih pola metra zemlje)
sada cu dodati jos jedan servisni ventil da bih pratio i podpritisak.
sistem nije prepunjen (oko 1 Kg R22) to ne bi trebalo da mu bude previse zar ne ?
a od posla i nemam bas puno vremena da trazim idealnu varijantu iovako mi treba po nedelju dana da cacnem nesto..
sugestije su dobro dosle i ako nisam upravu- recite KAKO da se grejemo na klimu u decembru i januaru to mi je primarni zadatak.
Wikipedia je pravi " sveti gral znanja " Odnedavno se tamo moze naci da je i Milos Obilic u stvari bio spitarski velikas
Jasta svasta
darkelja
darkelja's picture
Znas,nije pitanje u tome ko je koliki majstor,vec ko i koliko zeli drugom da pomogne.Nema veze ko je kakav i koliko osposobljen za neku tematiku,ako je rad da pomogne naci ce vremena za to.A sto se tice toga da svi vole da pametuju,to je postao standard u zemlji Srbiji,i naravno svi znaju posao bolje od samog majstora.Samo od takvih saveta neduznog kasnije boli glava a "savetodavac"....
tihi2
tihi2's picture
Registrovan dana: 02/05/2009
Na wiki može svako da stavi svoje znanje kao provereno. Tek kad se puno ljudi pobuni na glupost oni reaguju i skidaju. Nije merodavno.
Ja čekam rezultat kopanja i baš me zanima kako će se ta dobijena energija izmeriti objektivnom metodom da znamo kolika je, jel?
Koliki je COP tj koliko smo energije uštedeli?
A zanima me i da li bi bilo bolje da je ta rupa 20m dublja ili je bolje ako je 35.5m dublja.
goranfri
goranfri's picture
Registrovan dana: 31/03/2010
@Darkelja
Neki inženjeri tako izračunaše .
Reci bre čoveku kad već znaš te formule, da se ne muči.
Nike
Nike's picture
Klima se ledi kada je vani temperatura ispod 5°C i velika vlaga. Kada je temperatura ispod 0°C onda je zrak jako suh jer se većina vlage iz zraka smrznula. Tada klima puno manje ledi. Ima klima koje rade i na -20°C (Mitsubishi Zubadan i sl.) bez problema sa COP-om većim od 2. Ako vidiš santu leda na klimi onda je otapanje neispravno ili klima nije ispravna.
Dakle nije stvar dali se klima ledi ili ne, već koliki je protok energije preko izmjenjivača. On ovisi o toplinskom otporu izmjenjivača (nizak) i toplinskom otporu zemlje (visok). Pošto je otpor zemlje visok potrebna je velika površina na kojoj će se vršit izmjena topline.
Površina koju ima kondenzator na zrak je dovoljna ali toplinska vodljivost okružujuće zemlje je mala pa dolazi do toga da je oduzimanje topline okolnoj zemlji brže nego se ta toplina nadoknađuje (zbog visokog toplinskog otpora zemlje) pa se temperatura zemlje snižava konstantno.
Zbog toga oni koji rade geotermalne toplinske pumpe imaju veliku količinu cijevi u površinskom kopu ili duboke rupe. Kada se dobro dimenzionira onda u toku godine temperatura zemlje oko cijevi ne padne više od 3-4°C u odnosu na okolno zemljište. Zbog toga te klime nemaju otapanje i COP je oko 5.
Dali je sistem prepunjen ili ne vidi se iz pregrijanja plina (razlike između temperature zasićenja na usisu izmjerene manometrom i temperature cijevi na ulazu u kompresor). Kako je tu kapilara to pregrijanje ovisi o uvjetima na izmjenjivačima. Ako tekućina dođe do kompresora ( pregrijanje je 0 ili je pothlađeno) onda je prepunjen. Kako je u tebe izmjenjivač nedovoljan onda je nemoguće ispravno napuniti klimu, jer plin ne može ispariti zbog nedostatka topline koja je potrebna da promjeni agregatno stanje pa je klima u stvari uvijek prepunjena. To ti i govore hladne cijevi. Ako izmjeriš tlak i temperaturu cijevi, pa očitaš koliko je taj tlak u °C vidit ćeš da nemaš nikakvo pregrijanje a to znači da tekućina ide u kompresor i on ubrzo krepa.
Kupi Mitsubishi, Fujitsu, Daikin, Toshiba inverter koji uredno rade na -15
ili se uhvati pravog kopanja pa položi cijevi kako je navedeno na linku.
http://en.wikipedia.org/wiki/Direct_exchange_geothermal_heat_pump
P.S Ako to ne učiniš, ubrzo će ponestati kompresora u tvojoj okolini ako i nadalje nastaviš silovat tu svoju ideju.
Ako imaš bunar dovoljno blizu (ne dalje od max dužine cijevi za tu klimu i da visinska razlika nije veća od dopuštene) kroz koji voda pristojno protiče, onda možeš ubaciti vanjsku u bunar i onda mjeri koliko se temperatura vode mijenja s vremenom.
Ako padne za koji stupanj i ostane takva imaš rješenje problema.
goranfri
goranfri's picture
A ko drugi nego Nike može i hoće lepo da to objasni :bye2
E , a sad će Klimatizer da ti kaže da ti nemaš pojma kada imaš toliko vremena da pišeš po forumu a urednik darkelja će da se složi sa tim pa će da nam to malo bolje objasni jer odlično barata sa proračunima.
Ili će sada da se naljuti i obriše moj post a neće da nam objasni proračun.
Laughing out loud
Nike
Nike's picture
Jasta svasta
Kao i svaka informacija na webu i ta je diskutabilna. Međutim, ono što je napisano u članku koji sam linkao je prilično isparavno. Ili ti znaš da nešto nije?
Apriori odbacivati sve što dolazi iz Wikipedie je glupo. Ima tamo 90% vrlo korektnih informacija. Ako ne ništa, imaš linkove na izvore pa sam proučavaj.
tihi2
tihi2's picture
Rekao ja kako se formira znanje u Wikipediji. Lepo pročitaš, primiš k znanju sa rezervom, pa proveriš. Ne može drugačije.
Uostalom, ko skuplja informacije samo sa jednog izvora - nije baš ... iskusan. :nono Lako može da :tup :tup :tup
darkelja
darkelja's picture
goranfri wrote:
@Darkelja
Neki inzenjeri napravise formulu posle mnogo ulozenih godina rada,truda i naravno ogromnih kolicina ulozenog novca.Medjutim,kao i svaka formula ni ta ne vazi uvek i svuda.Prevrtljiva i cudljiva je ova nasa planeta zemlja,pa ni proracun nije isti za svako mesto na njoj.Dakle,pravo resenje problema moze da se postigne samo na licu mesta merenjem i uzimanjem u obzir svih parametara,a zatim detaljnim proracunom.Dakle,ne zelim nikog napamet da savetujem,ako nisam siguran da je ispravno to sto sam napisao.Jos da pojasnim da ja necu izlaziti na lice mesta,niti zelim da se upustam u racun sa nekim kome je svejedno sta ga drugi savetuju i samo se igra.Uostalom,njemu formule nista nece znaciti,a verovatno i ako ih bude razumeo-nece se voditi po njima.Uostalom,ja vec neko vreme uspesno pravim toplotne pumpe upravo sa inverter klimama,ali nisam ih ja izmislio,vec sam godinama prikupljao informacije i na kraju realizovao svoj projekat koji uspesno radi zahvaljujuci tome sto sam prikupljene informacije dobro proucio,malo vise razmisljao i na kraju nasao optimalno resenje za gotov proizvod koji funkcionise besprekorno,ne zakopavajuci metar po metar cevi po dvoristu.
darkelja
darkelja's picture
Laughing out loud
Zasto bih brisao post,nisi nista lose rekao.Ovo je forum slobodne volje da svako pise sta zeli,sve dok ne pocne da lupeta i ugrozava zdravlje i imovinu drugih svojim glupostima. :roll:
klimatizer
e zato sam i poceo ovu pricu..da se okupimo i razmenimo ideje..a sve u cilju ustede na mesecnom nivou za grejanje.
mislio sam ako budem uspeo da nabavim neki merni sat ili slicno da ga nakacim na produzni i tako merim potrosnju struje. a ako ne ima da iskljucim sve u kuci na 12 sati recimo i pogledam potrosnju.
Nike - spominjete neku dubinu od 20-30 m a kako bi se to moglo resiti sa kojim promerom cevi (zapremina sistema ?? ) - i ne necu kopati toliku rupu :nono (podstanar sam i ovako imam dovoljnu problematiku sa poluzatrpanom rupom)
darkelja - bi li podelio ideju sa nama mozda ?? Inverter mi je skup sad je oko 500-600 e neki pristojniji..
za ovaj projekat je ulozeno:
unutrasnja klima sa elektronikom (dzaba)
20m fi 10 (50e)
kompresor (polovan)
rupa 500 din ( komsa dzabalebaros)
i realno 3 dana po par sati do sada
nece mi biti problem da vam saopstim rezultate kakvi god oni bili...pa makar spalio jos jedan kompresor.. Wink jedino mi je zao sto ne mogu odvojiti to potrebno vreme da malo vise proucim materiju..jbg sam radim stalan posao +2 prekovremena posla (klime i satelitske antene)..
tihi2
tihi2's picture
Uložena struja se može tako meriti.
Meni je zanimljivija dobijena energija. Kako nju planiraš meriti? Kako ćemo znati šta se dobilo i koliko je to dobro?
Nike
Nike's picture
Dobivena energija se lako mjeri.
Klima, kada je čista i na nekoj brzini ima određen protok zraka. To se da naći u teh. podacima klime. Dovoljne je još samo izmjeriti precizno temperaturu zraka na ulazu u unutarnju jedinicu i temperaturu na izlazu.
http://www.engineeringtoolbox.com/heating-humid-air-d_693.html
klimatizer
to mene i kopka i zato nastavljam...prvobitno sam dobijao do 40-41 stepen na izlazu (sa prepunjenim sistemom - koji je radio PAR dana)
ova 2 varijanta sa zmijom mi je davala tj, šetala od 40 do 45 stepeni. ( sa oko 1 Kg gasa.
produžni mi se istopio i mislim da je smanjivanjem licni padao napon ( to je pitanje za električare jer se u struju baš i nerazumem) i mislim da je zato kompresor crko.
Anegdota jedna.
Uradili mi moji majtori neku klimu i zove čovek posle dan dva i kaže kako mu se spoljašnja jedinica pregreva i uopšte ne hladi...malo je bio podalje a i u sred sezone čekao je još možda dan da dodjemo.
šta biva..majstor nije odvrnuo usisni ventil.
Klima šljaka i dan danas a radi se o čistom kinezu.
Tako da mislim da kompresori i nisu toliko osetljivi već mogu oni dosta da izdže.
Pošto je majstor Rumun najgora kazna mu je bila da nas vodi na ribu u jednoj dobroj čardi..sećam se ja. Smile
termico
termico's picture
Registrovan dana: 18/09/2010
Postovani
Pitanje za npr Darkelju,da napomenem da nije zafrkavanje...
Cesto spominjan termin INVERTOR u vezi grejanja preko klima uredjaja..
U dve recenice,INVERTOR JE STA??????
Unapred hvala
Nike
Nike's picture
termico wrote:
Postovani
Unapred hvala
Ukratko, AC inverter je uređaj koji mrežnu struju frekvencije 50 Hz prvo ispravi u istosmjernu a onda tu istosmjernu ponovo pretvori u izmjeničnu s tim da joj mijenja frekvenciju kako traži procesor klime.
Pošto je u kompresoru asinhroni kavezni motor, njegov je broj okretaja (a time i kapacitet) "fiksan", tj ovisi o frekvenciji i broju polova motora.
Promjenom frekvencije dobiva se različit broj okretaja kompresora a time i promjenjiv volumni protok kompresora.
Kako je plin u klimi rjeđi što je niža temperatura okoline to je potreban veči volumni protok za isti maseni protok plina. Maseni protok plina određuje kapacitet klime, pa se tako postiže da i pri niskim vanjskim temperaturama imamo sličan kapacitet klime kao i s višim temperaturama jer se kompresor prilagođava uvjetima, a što nije slučaj s klasičnom klimom koja ima fiksni volumni protok i zbog toga joj opada kapacitet s padom vanjske temperature.
Eto, nadam se da nije prestručno.
Ima i DC inverter za DC kompresore a krajnji rezultat je isti, promjenjiva brzina kompresora.
termico
termico's picture
hvala na odgovoru,primetio sam da dosta ljudi ovde to nije znalo pa je suvise cesto rec invertor dovodilo u vezu sa nekim pogresnim stvarima kad je o klimatizaciji rec,poenta price je u umerenom priblizavanju zadatim parametrima a ne velikim oscilacijama kao kod on/off sistema.
Nike,svaka cast
darkelja
darkelja's picture
Eto,ja sad stigoh sa posla (radim jedan dan u godini,ali taj dan radim do kasno Laughing out loud ) i kako vidim Nike me je pretekao i objasnio sustinu.
mika_vk
mika_vk's picture
Registrovan dana: 28/10/2010
Pozdrav svima...
Prije svega klimatizer, svaka cast na ideji i na mudima da probas nesto!
Ne zelim ti pametovati i demoralizirati te, ali mislim da je kod tebe problem sto imas malu povrsinu na koju klima prenosi svoju hladnocu, tj s koje uzima toplinu... Trebao bi smisliti neki inverter koji ce ici na puno vecu povrsinu zemlje ili mozda napraviti nesto sto ja imam u planu...Prvi dio si napravio, zbog kojeg ti skidam kapu. Prestao si pametovati i probao prakticno nesto napraviti. SVAKA CAST!
E znaci kad ja sredim sasobom taj prvi dio, zbog oooogrooomniiih racuna za plin (oko 250E preko zimskih mjeseci) planiram nesto uciniti. Mislio sam staviti klimu sa inverterom u jednu prostoriju pa vidjeti utrosak struje vs. plina. No ovih dana sam odustao od toga, i razmisljam napraviti od te klime koju bi kupio toplinsku pumpu. Planiram sa bunarima to raditi, jer kod nas kad zakopas 2 aršova u zemlju, eto vode, tako da to nebi bio problem... Normalno nebi iskopao 2 arsova, nego bi busio bunare. mislio sam tu vodu dovoditi na klimu sto znaci da bi morao izmjeniti inverter (barem mislm da se to tako zove) i umjesto nutarnje jedinice napraviti "bure" u kojoj bi bila zavojnica koja ide sa TP i grije vodu u "buretu" a bure bi bilo spojeno na trenutni sustav centralnog grijanja. Problem je sto su u kuci radijatori, ali radijatori su stavljani po principu jedan naprema otprilike, pa i prije nego sto smo stavljali stiropor na kucu bilo je toplo. Ne planiram se grijati sa TP, nego odrzavati temperaturu vode u sustavu, pa kad se prostorije rashlade, mislim da ce plinskom bojleru biti puno jednostavnije dici temperaturu sa 35-40 C na 65-70C i jasno, meni puno ekonomicnije...
Svaka pomoc i savjet je vise nego dobro dosao... cak vidim da mi se ne isplati kupovati klimu, nego kompresor i inverter i "onajdrugivrag_kojicegrijatibure". Ako je netko pravio ili ima nacrt ili da mi pokaze kako to radi kod njega ili mozda zeli da zajedno probamo to napraviti bilo bi super da mi se javi. Ja sam inace iz Vinkovaca, Hrvatska....
Pozdrav svima....
stolegrom
stolegrom's picture
Registrovan dana: 19/01/2010
Ljudi, posto verujem da ovo ima da se kupi u radnjama koje prodaju delove za grejanje i sl...
Kako se ovo pravilno zove i gde da kupim?! Pravim nesto i treba mi velicina M4 i M5, da nakacim na neko crevce.
Ako sam omanuo temu, prebacite post tamo gde valja. Ni ja nisam bio siguran gde da pitam. :-/
stolegrom
stolegrom's picture
Zar niko nije video ovako nesto u svom zivotu? Majstori, pomagajte. Tongue
Такав део се назива полуспојница .
Не смем да тврдим али М4 и М5 навој ћеш јако тешко наћи да купиш . Али ако одеш код неког стругара то се лако може направити ....
stolegrom
stolegrom's picture
Zvao neke brojeve, al slaba vajda od tog navoja. Izgleda da cu morati da potrazim strugara. Laughing out loud
velikin
velikin's picture
Registrovan dana: 25/01/2011
Vise godina sam se prilicno uspesno grejao DC invertor klimom koja ima grejac kartera, grejace u kondez. posudi spoljne jedinice, R 410a gas... Ove zime, u najhladnijem periodu ( a bilo je dosta hladno) morao sam da ukljucim dodatno kalorifer od 2000w kako bi prebacio 20c. Da se to ne bi ponovo desavalo, dosao sam na ideju da do spoljne jedinice, vecim profilom cevi, dovucem relativno topao vazduh iz atmosferske kanalizacije (nalazi se na par metara) i spojim preko haube prilagodjene usisnom delu kako bi joj pvecao efikasnost...
Neznam da li je ovako nesto uopste moguce primeniti i ujedno vas pozivam da date svoja misljenja i procene, a na neka moguca pitanja predpostavljam da imam odgovore:
- Da li je vazduh u atm. kanalizaciji dovoljno topao? Da, sto dokazuju nezaledjene (vlazne) sahte u najhladnijem periodu.
- Da li ce cev moci da propusti dovoljnu kolicinu vazduha? Da, profil od par desetina centimetara moze da propusti ogromnu kolicinu vazduha, uostalom klima pre defrosta moze da radi vise desetina minuta, a u tom trenutku je isparivac potpuno okovan finim ledom i protok vazduha kroz isparivace je ravan nuli...
- Da li bi ovakav sistem doveo do tehnickih problema, kvarova...? Ne, spljasnja jedinica je projektovana da normalno funkcionise pod svim klimatskim uslovima (vetar, kisa, sunce,vlaga, sneg...)
- Da li ce se jedinica zalediti usled delovanja prilicno vlaznog vazduha? Ne, jer je pristigli vazduh uvek relativno topao (znacajno iznad nule) iz cega proizilazi da nema uslova cak ni za defrost...
- Da li ima dovoljno relativno toplog vazduha u sistemu? Predpostavka je: Da... U gradskim sistemima se nalaze kolometri cevi velikog profila-ogromne kubature koji su postavljeni duboko pod zemljom gde je temp. konstantna (izm. ost. upravo zbog pozitivne temperature), kroz koje tece voda koja takodje odrzava poz.temp. Problem bi,moguce, nastao (u slucaju da je ovo izvodljivo), kada bi se sve klime spojile na ovaj sistem i relativno brzo izvukle "topao" vazduh, ali vi ne sirite pricu i problema nema Wink.
- Da li ce se pojaviti neprijatni mirisi, vazduh opasan po zdravlje...? Ovo je vec filozofsko pitanje, pa evo i sl.odgovora: sigurno nece odisati planinskom svezinom, ali svi smo svedoci da iz sahti zimi konstantno kulja vazduh u obliku pare koji nema posebno neprijatan miris (inace bi odavno svi primetili nesto posebno), niti je potencijalno opasan po zdravlje, inace bi nam na to odavno bila skrenuta paznja i nadlezne sluzbe bi reagovale... Uostalom, zimi je intenzitet svakakvih mirisa redukovan, ljudi su minimalno van toplih prostorija, a nema uslova da taj vazduh udje u stambeni prostor ...
Delimicni zakljucak: U slucaju da je ovako nesto izvodljivo, a znajuci da je klima efikasnija u rezimu grejanja, postigli bi efikasno i jeftino grejanje, cak i sa neinvertorskim (jeftinim) klimama...
FMJ
FMJ's picture
Registrovan dana: 18/11/2011
A šta ćemo sa agresivnim isparenjima iz kanalizacije?
velikin
velikin's picture
FMJ, sasvim je sigurno da je vazduh u kanalizaciji konstantno veoma vlazan, na sta sam se i sam osvrnuo u jednom od svojih pitanja-odgovora. Ako uzmemo u obzir da je klima projektovana da radi i u okruzenju sa 100% vlaznosti..., onda je ta nedoumica nepotrebna... Sto se isplativosti tice, odavno je poznato i priznato da toplotna pumpa (sto klima ustvari jeste), daje odlican ucinak u odnosu na potrosnju... U slucaju klime, postoje resenja u vidu modernih invertora sa slozenom elektronikom koja su u stanju da prevazidju problem ekstremnih temperatura koje umanjuju efikasnost, ali su na zalost preskupe i postavlja se upravo pitanje opravdanosti tolike investicije. Ideja koju sam predstavio, omogucuje, hipoteticki, relativno jeftinim klimama ( bez preskupe elektronike i delova) da prevazidju problem ekstremnih temperatura...
Zvukoljube, pitanje kvaliteta vazduha koji bi "grejao klimu" je svakako diskutabilan, ali sam i u tom delu probao da kroz sopstveno pitanje dam odgovor, osim ako se ne radi o nekim posebno agresivnim isparenjima za koje je poznato da cirkulisu kroz kanalizaciju. Bilo bi mi veoma interesantno da navedes o kakvim se isparenjima, potencijalno radi... Samo da napomenem da to nije zatvoreni sistem (septicka jama npr.) gde se koncentrisu metan i jos pregrst opasnih gasova, vec atmosverska kanalizacija u koju se slivaju uglavnom suvisne vode sa ulica, trgova, trotoara... i ne postoje gasna zacepljenja... Cak da se radi i o fekalnoj kanalizaciji, situacija u tom smislu se ne manja bitno jer fekalije u odnosu na otpadnu tecnost iz domacinstva imaju ucesce u malom delu i u tom slucaju negativni efekti su nesto neprijatniji miris, ali se pojavljuje prilicno visa temperatura vazduha ( kljuc za ideju), sto uzrokuje bolje uslove za rad klime...
Hvala vam, svakako, obojici za osvrt na ideju... Verujem da postoji jos dosta uslova za diskusiju do konacnog zakljucka...
