Warning: Table './ssm_restore/watchdog' is marked as crashed and should be repaired
query: INSERT INTO watchdog
(uid, type, message, variables, severity, link, location, referer, hostname, timestamp)
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:a97601a77b18f47898e814764dce569a'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/kumkumasapun-i-izrada-sapuna?page=2', '', '172.70.134.5', 1684691722) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:1620:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>\\" <span style=\\"font-weight:bold\\">Ideja - imati je </span>\\". Mislila sam da je lako, ali nije. O cemu se radi? Hocu da pocnem da pravim DOMACI SAPUN ( cist, prirodan, kvalitetan ). Svaka informacija je dobrodosla. Dosta sam toga procitala, saznala, naucila... Ali? Uvek postoji ono \\" Ali \\". Kada sam htela da mu smislim IME :tup . E, tu je nastao problem :nes in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:cee18b5497d9447682d001f3c7276e71'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/kumkumasapun-i-izrada-sapuna?page=2', '', '172.70.134.5', 1684691722) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:2452:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>JEFTIN DOMAĆI SAPUN<br />\\nU tu svrhu treba uzeti<br />\\n500 g lužnog kamena<br />\\nte ga staviti u oveću staklenu posudu širokog grla, kakova se obično upotrebljava za kiseljenje krastavaca. Na taj lužni kamen nalije se<br />\\n1 litra kišnice.<br />\\nU tu otopinu baca se od zgode do zgode razne kosti, koje preostaju od jela, bilo od pečenja goveđeg, svinjskog, živ in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:e7903d711aca5f571f978163358046c1'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/kumkumasapun-i-izrada-sapuna?page=2', '', '172.70.134.5', 1684691722) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:6555:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Pravljenje sapuna podrazumeva koriscenje natrijum hidroksida (znanog i kao masna soda ili kausticna soda),koji je veoma opasna,otrovna i nagrizajuca supstanca.Pre nego sto se pocne raditi sa njom,potrebne su mere opreza.Za pravljenje sapuna koristiti samo emajlirano (bez IKAKVIH ostecenja),stakleno,gledosano keramicko,kameno ili posude od nerdajuceg celika,koje je otporno na toplotu (u kojem se moze kuvati).I plasticne posude su dobre,za kalupe,ali in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:230cecf27e70b6a0d43bab7c1f37fa15'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/kumkumasapun-i-izrada-sapuna?page=2', '', '172.70.134.5', 1684691722) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:1233:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Vec godinu dana proizvodim sapun koji se moze nazvati domacim. Ime mog sapuna je Zeleni Zec. U prvo vreme su ljudi pamtili sapun po tome sto ima neko cudno ime i upravo ga je ime izdvajalo iz ponude slicnih proizvoda.<br />\\nPrvi kontakt, ako nema licne preporuke, je IME i IZGLED. Zatim ga prinesu nosu i pomirisu. Znaci MIRIS. Na kraju kupe i tek kod kuce saznaju za CAROBAN OSECAJ pri koriscenju istog.<br />\\nB u d i in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:7386c0a1e2dce5fdf0f2aff893192617'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/kumkumasapun-i-izrada-sapuna?page=2', '', '172.70.134.5', 1684691722) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:353:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Nadam se a te nisam zbunila i da si donela odluku o imenu</p>\\n ', created = 1684691722, expire = 1684778122, headers = '', serialized = 0 WHERE cid = '3:7386c0a1e2dce5fdf0f2aff893192617'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:108;}', 3, '', 'http://www.samsv in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:2d855c29e61587e28ddff058a8f0d42d'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/kumkumasapun-i-izrada-sapuna?page=2', '', '172.70.134.5', 1684691722) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:340:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>evo i sapuna ako sam ovo odradila kako treba</p>\\n ', created = 1684691722, expire = 1684778122, headers = '', serialized = 0 WHERE cid = '3:2d855c29e61587e28ddff058a8f0d42d'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:108;}', 3, '', 'http://www.samsvojmajstor.com in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:2b1107fc23a60d237790fba2b269e58a'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/kumkumasapun-i-izrada-sapuna?page=2', '', '172.70.134.5', 1684691722) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:357:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>izgleda da je uredu<br />\\nevo jos u malo vecem formatu</p>\\n ', created = 1684691722, expire = 1684778122, headers = '', serialized = 0 WHERE cid = '3:2b1107fc23a60d237790fba2b269e58a'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:108;}', 3, '', 'htt in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:0c4207e1f025bf690a35a8529695853d'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/kumkumasapun-i-izrada-sapuna?page=2', '', '172.70.134.5', 1684691722) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:392:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>evo jos<br />\\njedan je sa kafom<br />\\na drugi sa kozjim mlekom i narandzinom korom</p>\\n ', created = 1684691722, expire = 1684778122, headers = '', serialized = 0 WHERE cid = '3:0c4207e1f025bf690a35a8529695853d'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\&quo in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:7753a573e4df9ef624625d511e60ec53'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/kumkumasapun-i-izrada-sapuna?page=2', '', '172.70.134.5', 1684691722) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:306:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>:+ :+ :+</p>\\n ', created = 1684691722, expire = 1684778122, headers = '', serialized = 0 WHERE cid = '3:7753a573e4df9ef624625d511e60ec53'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:108;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/kum in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:d6c59d021633289caa6891649e1e7136'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/kumkumasapun-i-izrada-sapuna?page=2', '', '172.70.134.5', 1684691722) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:1184:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Aurora, hoce li sapun biti na trzistu ove godine ili ne...<br />\\nZnam da si ciljala na mene kad sam naisao na neke dijelove u poslednjem tvom postu...Ma tako mi svejedno,ako si bas na kraj srca pa se ljutis, ali nisam imao lose namjere nego da unesemo malo humora dok formula za dobar sapun ne bude potvrđena.<br />\\nUsput da izrazim divljenje tvojoj sklonosti i smislu za pisanje.Ovo ozbiljno mislim i rekao bih da se i in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:a610ad1fe7fd116bab7ea9fa6a7808f0'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/kumkumasapun-i-izrada-sapuna?page=2', '', '172.70.134.5', 1684691722) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:336:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Ja mislim da to neće moći bez sapuna!?</p>\\n ', created = 1684691722, expire = 1684778122, headers = '', serialized = 0 WHERE cid = '1:a610ad1fe7fd116bab7ea9fa6a7808f0'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:108;}', 3, '', 'http://www.samsvojmajstor.com/por in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:564981265276db4bf316aad8634c9dc9'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/kumkumasapun-i-izrada-sapuna?page=2', '', '172.70.134.5', 1684691722) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:1345:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>pljoska ,malo je reci hvala,sve sto si napisala za mene je pravo otkrovenje,lutala sam po netu...ima divnih linkova na netu...ali nikako doci do mera i kolicina....zanimaju me ovi sapuni koji se spremaju na ulju i kuvaju 15-20 min...to cu probati koliko sutra kod kuce neku manju kolicinu,pionir sam u ovome ali sticajem okolnosti sam ostala bez posla preko noci,imam dva sjajna studenta,sama ih izdrzavam i bila bi velika steta da na kraju odustanu od in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:6e618c69d26bf051ade5fe825b4485da'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/kumkumasapun-i-izrada-sapuna?page=2', '', '172.70.134.5', 1684691722) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:1049:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Ja sam 2001 koji je ovo procitao i eto mee <img src=\\"http://www.samsvojmajstor.com/portal/sites/all/modules/smileys/packs/Roving/smile.png\\" title=\\"Smile\\" alt=\\"Smile\\" class=\\"smiley-content\\"/> Malo mi je sve ovo po sistemu \\"Ne znam hta hocu ali hocu odmah\\" Mislim da je lutajuca postavila stvar bas onako kako treba. Ime jeste sva in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:a0a7ad1c9246849fd6384cb201cc7fc2'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/kumkumasapun-i-izrada-sapuna?page=2', '', '172.70.134.5', 1684691722) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:995:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p><div class=\\"bb-quote\\"><b>zzec99 wrote:</b><blockquote class=\\"bb-quote-body\\">izgleda da je uredu<br />\\nevo jos u malo vecem formatu</blockquote></div><br />\\nSjajne fotografije. <img src=\\"http://www.samsvojmajstor.com/portal/sites/all/modules/smileys/packs/Roving/lol.png\\&am in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:c1b0591a2170eb9df88f00a8b202923a'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/kumkumasapun-i-izrada-sapuna?page=2', '', '172.70.134.5', 1684691722) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:343:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>nisu mozda bas profesionalne ali mi se dopadaju</p>\\n ', created = 1684691722, expire = 1684778122, headers = '', serialized = 0 WHERE cid = '3:c1b0591a2170eb9df88f00a8b202923a'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:108;}', 3, '', 'http://www.samsvojmajstor. in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:f8ca36e8eaef2d74bd51fa19ce0efce1'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/kumkumasapun-i-izrada-sapuna?page=2', '', '172.70.134.5', 1684691722) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:1584:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Meni se ideja vrzma u glavi vec duze vremena. Procitavsi tekstove na ovom forumu,resio sam da krenem u realizaciju.<br />\\nDosta sam ovde saznao ali me interesuju neke sitnice.</p>\\n<p>1/ Ideja da kalupi budu modle za kolace je dobra. intersuje me kako teflon reaguje na masu koja se razliva. da li sme u takve posude da se sipa .ovo pitam jer mi se necija ideja ovde sa teflonskim modlama svidela,jer ih ima in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:974d80d801ae88264227d504baaa1b8e'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/kumkumasapun-i-izrada-sapuna?page=2', '', '172.70.134.5', 1684691722) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:1887:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>1. tflon nije resenje jer se skida zajedno sa sapunoom tj ostaje na sapunu<br />\\n 2. kako pravim hladnim postupkom bez kuvanja , ne postizem velike temperature, i sve dodatke dodajem na kraju sjedinjavanja a pre pocetka hladjenja tj mesanja da se ravnomerno i postepeno ohladi. dodatke uglavno koristim u sasusenom stanju jer su tako sasusena vec konzervirana i da mi nece dati nezeljene efekte<br />\\n 3. etericna in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:51d28fa9b5c6a7f3bb5bc9f5971ff7a9'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/kumkumasapun-i-izrada-sapuna?page=2', '', '172.70.134.5', 1684691722) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:1309:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>ZZec!<br />\\nMnogo hvala na iscrpnim odgovorima. za pocetak ste mi jako pomogli jer skupljam sve korisne informacije.Inace zivim u C.Gori,pa me interesuje da li se ta ulja mogu kupiti negde van Krusevca.Inace ovde u Baru pronasao sam jestivo palmino ulje u kantama od 3 litra. cena je oko 3,60 eura za celu kantu/1,20 eura po litri/ Sta mislite o tome,mislim sto se tice izbora sirovine i njenih osobina.sta biste mi jos preporucili od m in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:cb51391feb05e59446be931e189d9e17'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/kumkumasapun-i-izrada-sapuna?page=2', '', '172.70.134.5', 1684691722) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:884:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>u Krusevcu se kupuju mirisi za sapune a ne ulja, a palmino ulje je sasvim u redu . mozete jos koristiti i maslinovo ulje koje imate sigurno u prodavnicama kod vas<br />\\nkupujte ulja koja mozete naci bez velike muke, kao sto je ricinusovo ulje - u apotekama - a recepte ce te naci na netu. ima ih dosta jedino sto su uglavnom na engleskom ali verovatno ce te uspeti da prevedete i prilagodite sebi.<br />\\nkokosovo ulje je in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:7b9d463f13435c5dc7fbffdac4cc5ded'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/kumkumasapun-i-izrada-sapuna?page=2', '', '172.70.134.5', 1684691722) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:493:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>XXec!<br />\\nVidim da ste vrlo azurni i korektni. Interesuje me da mi pojasnite taj vas hladni postupak,naravno ako zam ne oduzima mnogo vremena. kao i da li moze da se koristi margarin.Hvala</p>\\n ', created = 1684691722, expire = 1684778122, headers = '', serialized = 0 WHERE cid = '3:7b9d463f13435c5dc7fbffdac4cc5ded'\";s:5:\"%file\";s:76:\"/home/admin/d in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:5b37ee8c6fd9aab033c98c6a2220fbee'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/kumkumasapun-i-izrada-sapuna?page=2', '', '172.70.134.5', 1684691722) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:1097:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>verovatno moze i margarin ali ne znam koja su mu svojstva<br />\\nhladni postupak se svodi na t da masnoce ne kuvate vec ih grejete do temperature kada ce se sao rastopiti i sjediniti medjusobno. zavisno od masnoca koje koristite bitno je da ih ne pregrejete jer ih onda treba i hladiti.<br />\\nkako i soda dok se rastvara u vodi razvija odredjenu temperaturu koja i nije tako mala vazno je da je rastvarate u posudi koju s in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:26107f71bdfa48b14df7bb14555be14b'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/kumkumasapun-i-izrada-sapuna?page=2', '', '172.70.134.5', 1684691722) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:410:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Mislim da brojka od skoro 59000 pogleda na ovu temu zasluzuje da se svaki sapun zove AURORA. :ahaha :hh :hh :hh</p>\\n ', created = 1684691722, expire = 1684778122, headers = '', serialized = 0 WHERE cid = '3:26107f71bdfa48b14df7bb14555be14b'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\&quo in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
VALUES
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:ce6d013897bf296ef35eb03b9442af35'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/kumkumasapun-i-izrada-sapuna?page=2', '', '172.70.134.5', 1684691722) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:598:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Naravno .Mnogo ste mi pomogli sa samo dva tri kratka saveta.Interesuje me da li je prikladnija tecna soda ili cvrsta/valjda u granulama,ne znam/. Gde se moze nabaviti i koja joj je cena. kada se sapun razlije u kalup,posle koliko vremena ga mogu seci na odredjenu velicinu,a da ne napravim kakvu stetu.</p>\\n ', created = 1684691722, expire = 1684778122, headers = '', serialized = 0 WHERE cid = '3:ce6 in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:39503e60048e4f03831b795e4bd43fab'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/kumkumasapun-i-izrada-sapuna?page=2', '', '172.70.134.5', 1684691722) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:629:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Kako bi bio siguran da neces pogresiti, mislim da je najbolje da se vratis na neku od prethodnih stranica ove teme i priupitas Auroru, ona je izgleda te dileme rijesila dok nam se ne javlja .pises joj brate na p.p. mozda ti se javi.<br />\\nMoje skromno znanje govori da je najbolje ostaviti sapun da prenoci kako bi se ohladio.</p>\\n ', created = 1684691722, expire = 1684778122, headers = '', se in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
VALUES
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:baad48149e4944ce730cf1f6b417fc92'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/kumkumasapun-i-izrada-sapuna?page=2', '', '172.70.134.5', 1684691722) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:789:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>koristim sodu u granulama ili ljuspicama. mozes je kupiti u skoro svakoj poljoprivrednoj apoteci. kosta oko 100 din<br />\\n sapin treba da odstoji od 24-48 sati u kalupu a ako je jos uvek mek na dodir i duze jer bi se inace deformisao pri vadjenju<br />\\nkao sto rece creatino pokusaj da nadjes kod aurore korisne savete za pocetak.<br />\\nmoram priznati da nisam citala predhodne stranice ali ti kako sada t in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:456f73cc7be4ec2e9d494f0237d68e34'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/kumkumasapun-i-izrada-sapuna?page=2', '', '172.70.134.5', 1684691722) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:560:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Mozete li mi pojasniti kako se dobijaju ove boje sapuna. Mislim sta se koristi za bojenje i kako se dobije ovako nijansirana boja.predpostavljam da se dve odvojene smese mesaju ali ne skroz pa tako ostaju ukrasni slojevi i tragovi,kao kada zene prave slican kolac.</p>\\n ', created = 1684691722, expire = 1684778122, headers = '', serialized = 0 WHERE cid = '3:456f73cc7be4ec2e9d494f0237d68e34' in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:a411f1505ed29f6ed015355c80e33c51'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/kumkumasapun-i-izrada-sapuna?page=2', '', '172.70.134.5', 1684691722) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:420:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Mislim na ovakve varijante. Cime se i kako dobijaju ove boje ,prelivi i nijanse.Koji su to zacini,dodaci i kakve boje.. :tup</p>\\n ', created = 1684691722, expire = 1684778122, headers = '', serialized = 0 WHERE cid = '3:a411f1505ed29f6ed015355c80e33c51'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\" in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:d0bea0469d9fa2a384834f4646df76b2'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/kumkumasapun-i-izrada-sapuna?page=2', '', '172.70.134.5', 1684691722) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:392:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Da li je neko uspeo konačno da napravi sapune, pošto ima zainteresovanih za kupovinu na više.</p>\\n ', created = 1684691722, expire = 1684778122, headers = '', serialized = 0 WHERE cid = '3:d0bea0469d9fa2a384834f4646df76b2'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:108;}', in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:93c6fe160653dc82fa0bf8dd8cb7a33b'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/kumkumasapun-i-izrada-sapuna?page=2', '', '172.70.134.5', 1684691722) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:506:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>KONACNO? pa pogledaj<br />\\n<a href=\\"http://www.zelenizec.com\\" title=\\"www.zelenizec.com\\">www.zelenizec.com</a><br />\\nmislim da ces tu naci odgovor na proizvodima</p>\\n ', created = 1684691722, expire = 1684778122, headers = '', serialized = 0 WHERE cid = '3:93c6fe160653dc82fa0bf8dd8cb7a33b' in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:73c89084193409d795542437c89b539b'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/kumkumasapun-i-izrada-sapuna?page=2', '', '172.70.134.5', 1684691722) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:399:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>draga, a mozes se vratiti i na stranu 5 ove sobe i pogledati i ovde kako izgledaju ovi koji su uradjeni</p>\\n ', created = 1684691722, expire = 1684778122, headers = '', serialized = 0 WHERE cid = '3:73c89084193409d795542437c89b539b'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:108;}& in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:a13281594cb5c013506dc4b52d2d6d19'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/kumkumasapun-i-izrada-sapuna?page=2', '', '172.70.134.5', 1684691722) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:404:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Sjajno. Moju drugaricu zanimaju sapuni figurice ili razni oblici, recimo srca, i da to budu manji sapuncici.</p>\\n ', created = 1684691722, expire = 1684778122, headers = '', serialized = 0 WHERE cid = '3:a13281594cb5c013506dc4b52d2d6d19'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:1 in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:3e77887fda86fbc96b6dd85b1ed03dc1'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/kumkumasapun-i-izrada-sapuna?page=2', '', '172.70.134.5', 1684691722) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:420:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>nazalost u proizvodnji imam samo upotrebne kvalitetne sapune ali na prvi pogled su mozda neugledni tako da ti ne mogu pomoci</p>\\n ', created = 1684691722, expire = 1684778122, headers = '', serialized = 0 WHERE cid = '3:3e77887fda86fbc96b6dd85b1ed03dc1'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\" in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '2:abfecc63f09f063c306e2753273f32e4'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/kumkumasapun-i-izrada-sapuna?page=2', '', '172.70.134.5', 1684691722) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:942:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = '<p><iframe id=\\'a431a3a0\\' name=\\'a431a3a0\\' src=\\'https://adserver.samsvojmajstor.com/adserver/www/delivery/afr.php?zoneid=26&amp;cb=9900435235423422\\' frameborder=\\'0\\' scrolling=\\'no\\' width=\\'728\\' height=\\'90\\'><a href=https://adserver.samsvojmajstor.com/adserver/www/delivery/ck.php?n=afcbc006&amp;cb=99004352 in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '2:ca011fdebe3a51dea5859d4aba19f564'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/kumkumasapun-i-izrada-sapuna?page=2', '', '172.70.134.5', 1684691723) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:956:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = '<p><iframe id=\\'a354bc39\\' name=\\'a354bc39\\' src=\\'https://adserver.samsvojmajstor.com/adserver/www/delivery/afr.php?zoneid=27&amp;cb=002874370149734552\\' frameborder=\\'0\\' scrolling=\\'no\\' width=\\'234\\' height=\\'160\\'><a href=\\'https://adserver.samsvojmajstor.com/adserver/www/delivery/ck.php?n=aa83fdd3& in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '2:64a277481435f3c6a7b18eb6fa57f957'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/razno/kumkumasapun-i-izrada-sapuna?page=2', '', '172.70.134.5', 1684691723) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:868:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = '<p><iframe id=\\'a694a55c\\' name=\\'a694a55c\\' src=\\'https://nepremicnine.click/www/delivery/afr.php?zoneid=99&amp;cb=43241234\\' frameborder=\\'0\\' scrolling=\\'no\\' width=\\'300\\' height=\\'600\\'><a href=\\'https://nepremicnine.click/www/delivery/ck.php?n=a9f8f8a5&amp;cb=63456\\' target=\\'_b in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135 Kum(Kuma)Sapun i izrada sapuna | www.samsvojmajstor.com
JEFTIN DOMAĆI SAPUN
500 g lužnog kamena
1 litra kišnice.
U tu otopinu baca se od zgode do zgode razne kosti, koje preostaju od jela, bilo od pečenja goveđeg, svinjskog, živadi, ribe i t. d. Veće kosti, kao one od šunke, treba dakako razbiti na manje komade i slagati u tu otopinu, te po potrebi dodavati toliko kišnice. da su sve kosti pokrite. Kada se ta staklena posuda napuni do vrha, a bit će u njoj po prilici 3—4 kg kostiju, ostavi se stajati 12—15 dana.
Osim kosti, može se u tu staklenu posudu bacati i druge otpatke, kao korice od sira, kožice od slanine i t d.Svi ti otpatci će se u posudi raspasti. Tada se uzme kakovu veću posudu od desetak litara i u nju se saspe čitav sadržaj iz staklene posude, dolije se još
2 litre vode
i kuha barem dva sata, računajući od početka vrijenja.
Sada treba tu masu procijediti kroz cjedilo, eventualne ostatke kostiju i kožica odstraniti, te ostaviti ocijeđenu smjesu u istoj posudi do drugog dana. Drugi dan pristavi se posuda opet na vatru da zakipi i kada zakipi doda se u smjesu
50 g potaše,
pa pustiti da se sve zajedno kuha 1 sat. Za to vrijeme priredi se odgovarajuća drvena kutija, sandučić, koji se iznutra obloži starom, vlažnom krpom.
Kad je smjesa kipila 1 sat doda joj se 2—3 šake kuhinjske soli i posudu odstavi od vatre. Kašu, koja je nastala u posudi, pretoči se u priređenu drvenu kutiju, koju se postavi nad kakovo korito, u koje će iscuriti prekomjerna lužina.
Drugi dan istrese se sapun iz kutije, te se pusti nekoliko dana da se onako u komadu suši. Kad se sapun posušio, izreže ga se u odgovarajuće komade po volji i ostavi da se tako rezan suši.
Ovako dobiveni sapun izdašan je, obilno se pjeni dobro pere, a što je glavno dade se priugotoviti lako, brzo i skoro bez ikakovih troškova.
Pravljenje sapuna podrazumeva koriscenje natrijum hidroksida (znanog i kao masna soda ili kausticna soda),koji je veoma opasna,otrovna i nagrizajuca supstanca.Pre nego sto se pocne raditi sa njom,potrebne su mere opreza.Za pravljenje sapuna koristiti samo emajlirano (bez IKAKVIH ostecenja),stakleno,gledosano keramicko,kameno ili posude od nerdajuceg celika,koje je otporno na toplotu (u kojem se moze kuvati).I plasticne posude su dobre,za kalupe,ali samo one koje izdrzavaju toplotu preko 90 stepeni.Nikako ne stavljati ovu supstancu u limeno,aluminijumsko ili cinkano posude,jer ce reakcija biti burna i otrovna.
Dalje je vazno nositi zastitnu opremu:rukavice,naocare i masku za lice (preko nosa i usta).Uvek drzite pri ruci sirce.Ako masna soda dodirne kozu,isperite odmah mesto sircetom,a onda vodom.Masna soda ne deluje u trenutku,pa cete prvo osetiti svrab i peckanje,u kom slucaju odmah reagujte sa sircetom.UVEK NOSITE ZASTITNE NAOCARE,jer je sodu veoma tesko isprati sa ociju u koje upadne,a ako vec gori kozu,zamislite sta moze ocima.
I ne brinite:masna soda se nece zadrzati u sapunu.Svi sapuni se prave tako,ali sam sapun ne sadrzi masnu sodu.To je zato sto masna soda reaguje sa mastima i stvara tri molekula sapuna i jedan glicerina.Znaci,kada se "proizvodnja" zavrsi,nje vise nema,samo sapun i glicerin.
Sada,kada sam to objasnila,da kazem sta vam treba:
Veca posuda za mesanje masne sode i vode (od materijala koje sam pomenula gore)
dublja "serpa",posuda za kuvanje (od materijala koji sam pomenula gore)
Plasticna ili drvena varjaca (koju necete koristiti nizasta drugo posle)
Zastita ociju (nosite makar suncane naocare) i ostala zastita
Vaga za merenje "masti" i masne sode
Sat ili kuhinjski tajmer
Kalupi za sapun (ne moraju biti fabricki pravljeni,mada ima i toga po prodavnicama,ali moraju biti od nekog od pomenutih sigurnih materijala)
masni papir,koje cete iseci tako da je tacno oblika modle u koju sipate sapun
Sastojci koji su vam potrebni su za vecu kolicinu (ne nesto preterano veliku,otprilike 5-6 sapuna) a ako hocete manju,smanjite srazmerno mere,ali sa paznjom.Takode naglasavam da sam mere "prevela" sa americkog mernog sistema (jer je moj recept na americkom engleskom) pa mozda izgledaju malo cudno.Ipak,to je to.Znaci:
1 kg 360 gr masnoce (puter ili ulja,koja su odlican izbor,ali im treba duze vremena da se stegnu (maslinovo ulje je moje licno omiljeno,ali njegov miris je malo tezi (zato je jako lekovito i dobro za kozu)...slobodno mozete da koristite i kokosovo,koje ima lepsi miris,ili palmino,a cak i kukuruzovo ili suncokretovo dolaze u obzir,ako su vam pri ruci)
340 gr masne sode (ovo vazi ako je u granulama,ako je u tecnosti onda 340 ml),za koju morate biti sigurni da je 100% cista masna soda,pa je najbolje da je kupite u apoteci
3 solje vode (solje od po 2 dl,znaci 6 dl,destilovane ili flasirane,cesmusa ne dolazi u obzir)
suvo bilje po zelji (lavanda,bosiljak,maticnjak ili sta vec) od 3 kasike do 3/4 solje
etericno ulje neke biljke po zelji 3-6 kasika
2 do 4 kasike ricinusovog ulja
malo limunske kiseline ((limuntus) da uravnotezi ph vredonost)
Priprema:
Vodu dobro ohladite (neka prenoci u frizideru (NE u zamrzivacu)).Tako ohladenu,sipajte je u sud u kojem cete praviti sapun.POLAKO dodajte masnu sodu,stalno mesajuci plasticnom ili drvenom varjacom.NIKAKO NE UDISITE PARU KOJA SE DIZE,OTROVNA JE I NAGRIZA GRLO!
Tecnost ce postati veoma topla,kao da vri!Kada ste je promesali,odlozite je na neko hladno i sigurno mesto (van domasaja dece,zivotinja ili bilo koga ko ne zna sta sadrzi),da stoji najmanje 1 sat.
Dotle sipajte ulje ili puter u dublju serpu,umesajte bilje ili etericno ulje i ostavite da stoji na sobnoj temperaturi.Kada je masna soda spremna (posle sat ili vise),sipajte je veoma polako i veoma pazljivo,preko masnoce/ulja u serpi.Masnoca/ulje ce se rastopiti.Stavite serpu pazljivo na sporet, i "kuvajte" ovo na najmanjoj mogucoj temperaturi izmedu 15-20 min,STALNO mesajuci.Skinite sa vatre,dodajte ricinusovo ulje pomesano sa limunskom kiselinom,promesajte i razlijte u kalupe (ako nemate kalupe,razlijte sapun u bilo koji sud od pomenutih sigurnih materijala).
Odmah prekrijte kalupe sa masnim papirom,dobro ga pritisnite uz sam sapun (trebalo bi zadrzati vazduh napolju,da bi se sprecilo nastajanje tkz. "sodne prasine" i ostavite da se sapun susi.U zavisnosti od ulja/masnoce,susice se od 3 do 8 nedelja.Sto duze stoji,sapun postaje blazi za kozu (ph vrednost mu opada i postaje blag).Kada osetite da je potpuno cvrst,blago ga pogurajte nozem iz kalupa (tako bi u kalupima trebala da ostane tkz. sodna prasina,koja se stvara pri dodiru sapuna i vazduha) i sastruzite ostatke prasine,ako ih ima.Mozete i blago isprati sapun hladnom vodom,trljajuci ga i skidajuci i poslednje tragove prasine.
Jos nesto:ricinusovo ulje nije obavezno,ali "omeksava" sapun.Ipak,ako ne zelite da ga koristite,ne morate.Sapun ce u tom slucaju biti cvrsci.
Ako zelite da sapun mirise MORATE dodati i neko etericno ulje.U suprotnom,sapun ce imati izrazito "sapunast" miris (oni koji su ikada videli domaci sapun,znaju sta mislim).
Umesto vode mozete da stavite i neki biljni caj (takode dobro ohladen) ali treba imati na umu da posle hladenja i kuvanja u njemu zaista nece ostati mnogo od dobrih vrednosti.
I to je to...nije mnogo tesko,ali iziskuje dosta truda.Ipak,ako se plasite masne sode ili samo ne zelite da se bakcete sa svim tim,ima resenja.Kupite neki fini,bezmirisni beli sapun u prodavnici (u ovom slucaju,pricam o jednom komadu,ako kupite vise,povecajte kolicinu vode i bilja) i isecite ga na komadice.Prelijte sa 1-2 dl vode i kuvajte na laganoj vatri.Onda dodajte 1 kasiku suvog bilja koje zelite i nekoliko kapi etericnoj ulja,takode po zelji.Dobro izmesajte,sipajte u kalup i ostavite da se stegne,kao i domaci sapun.
B u d i h r a b r a i guraj neki samo svoj licni stos.
Uostalom seti se npr
RIBLJA CORBA
BIJELO DUGME...
Prvo je nastalo ime. Ko je tada znao da oni i sviraju dobro???
Poslala bih i slike sapuna ali izgleda mi komplikovano.
Uskoro ce se sapuni pojaviti i na nasem sajtu www.zelenizec.com
Usput da izrazim divljenje tvojoj sklonosti i smislu za pisanje.Ovo ozbiljno mislim i rekao bih da se iz tog talenta moze izbrusiti daleko veca vrijednost, od ove koju planiras sa sapunom.
Ne kazem da treba odustati od sapuna vec njegovati ovaj drugi talenat o kome pisah...
Eto.., drugarski pozdrav u javljanju iz dobrih namjera...
pljoska ,malo je reci hvala,sve sto si napisala za mene je pravo otkrovenje,lutala sam po netu...ima divnih linkova na netu...ali nikako doci do mera i kolicina....zanimaju me ovi sapuni koji se spremaju na ulju i kuvaju 15-20 min...to cu probati koliko sutra kod kuce neku manju kolicinu,pionir sam u ovome ali sticajem okolnosti sam ostala bez posla preko noci,imam dva sjajna studenta,sama ih izdrzavam i bila bi velika steta da na kraju odustanu od studija zbog prodaje moje firme i mog posla...pa s toga nemam puno vremena moram vrtoglavo brzo da smislim sta da radim...sapuni su mi se ucinili interesantnim zato sto ih sama koristim kad god mogu,bas te rucne izrade,malo sam se bavila i kozmerikom pre par godina pa odatle se i razumem u etericna ulja posto sam koristila aromaterapiju...nadam se da ce mi uspeti...zaista ti puno hvala..ulepsala si mi dan...zzec 99 hvala na sugestijama za ime o tome cemo po tom,samo da sapun uspe pa onda cemo se baciti na ime...svakako svaki predlog je dobrodosao...puno pozdrava za oboje...dragi prijatelji
Ja sam 2001 koji je ovo procitao i eto mee Malo mi je sve ovo po sistemu "Ne znam hta hocu ali hocu odmah" Mislim da je lutajuca postavila stvar bas onako kako treba. Ime jeste svakako bitno ali ti koliko ja vidim imas tu jos ihaaa aktivnosti do krstenja. Sta te ceka kod pakovanja, stampe, izrade kutije i slicno (a po vec pomenutim visokim kritereijumima) da i ne pominjem.
Evo da dam svoj skromni doprinos:
Mystik green,
Taboo
Creativ Healty Manufacture ili skraceno "CMF"
1/ Ideja da kalupi budu modle za kolace je dobra. intersuje me kako teflon reaguje na masu koja se razliva. da li sme u takve posude da se sipa .ovo pitam jer mi se necija ideja ovde sa teflonskim modlama svidela,jer ih ima raznih oblika i velicina gotovo na svim pijacama i radnjama.
2/ kada se dodaju dodaci/bilje/.da li posle kuvanja,a pre izlivanja u kalupe. da li se dodaju sveze biljke ili suve.kako se na primer dodaje,cimet,kafa,narandzina kora,ruzmarin,
3/znam da su etericna ulja dosta skkupa. Koja je kolicina potrebna za npr. 1kg. gotovog sapuna.
4/ Cime se postizu mirisi osim etericnim uljima.
5/ kako se dodaju ovsene i zobene klice,ruzine latice,kokos,badem i sl.
Znam da sam mozda malo dosadan za onoga kome je ovo rutina. Ali shvatite sebe kada ste pocinjali.
inace zivim u crnoj gori na moru i mislim da proizvodim u malim kolicinama za licne potreebe i potrebe nasih gostiju u apartmanima.
3. etericna ulja su malo komplikovana za upotrebu jer se moraju znati razne note i za to je potrebno da se malo vezba jer postoje bazicn , srednja i gornja ulja koja treba uskladiti jedna s drugima a i sa sopstvenim nosom, a kao sto kazes skupa su pa je i to istrazivanje skupo dok ne dodjes do mirisa koji je svojsven amo tebi i tvojoj proizvodnja a pri tom i prija korisnicima istog. morao bi da imas razne varijante i zato ti za pocetak preporucujem mirise za sapune koje mozes kupiti u Aromi Krusevac ( mislim da se tako zove) otprilike ide 20ml na 1 kg sapuna ali ne mozes kupiti manje od 1l i kosta negde izmedju 2-3000 din.
4. na ovo pitanje mislim da vec imas odgovor mada mozs praviti sapune i bez bilo kakvih dodatnih mirisa vec samo sa dodacima koji ostavljaju neki mirisni trag sami po sebi
5. za kokos i badem ne znam jer nisam koristila to u mojoj proizvodnji, a ovsene pahulje dodajem kao i sve ostalo sto dodajem i vec sam objasnila. ruzine latice prvo naberes, pa osusus- najbolje napolju u hladovini izmedju dva sita za prosejavanje brasna. pri dodavanju u sapun ce promeniti onu lepu boju i nemoj da te to iznenadi.
ZZec!
Mnogo hvala na iscrpnim odgovorima. za pocetak ste mi jako pomogli jer skupljam sve korisne informacije.Inace zivim u C.Gori,pa me interesuje da li se ta ulja mogu kupiti negde van Krusevca.Inace ovde u Baru pronasao sam jestivo palmino ulje u kantama od 3 litra. cena je oko 3,60 eura za celu kantu/1,20 eura po litri/ Sta mislite o tome,mislim sto se tice izbora sirovine i njenih osobina.sta biste mi jos preporucili od masnoca npr....vas savet.
sada malo davim...osecam,ali ako vam nije tesko da mi na najednostavniji nacin pojasnite taj vas hladni postupak. U kratkim crtama kako se pravi i sta se radi.
kokosovo ulje je malo problematicno za nalazenje bar u Srbiji ali mozda kod vas i nije. potrazite ga u prodavnicama zdave hrane. ono vam je potrebno da bi sapun imao penu
XXec!
kako i soda dok se rastvara u vodi razvija odredjenu temperaturu koja i nije tako mala vazno je da je rastvarate u posudi koju stavite u vecu posudu sa ledom da ne bi doslo do prevelikog zagrevanja
na kraju je najbitnije da rastvorenu sodu sjedinite sa masnocama na priblizno istoj temperaturi stim sto se tolerise razlika od par stepeni od 2-4C
neko kaze da je najbolja temperatura 28 stepeni a ja radim od 30 do 35 C
nadam se da sam pomogla koliko toliko
moram priznati da nisam citala predhodne stranice ali ti kako sada tek pocinjes procitaj. predpostavljam da je aurora iskusan prakticar
JEFTIN DOMAĆI SAPUN
500 g lužnog kamena
1 litra kišnice.
2 litre vode
50 g potaše,
