Woody - program za konstruisanje plocastog namjestaja
6 poruka / 0 new
zarelik
zarelik's picture
Registrovan dana: 23/11/2008
Neko je trazio woody program, pa sam ga nasao. Dijelim ga sa vama.
Meni nije lako crtati u njemu i nakon nekog vremena, odustao sam.
Ako neko ima tutorial neka postavi.
Linkovi za woody:
Part 1
Code:
http://rapidshare.com/files/67933962/WooCadWoo2ISO.part1.rar
Part 2
Code:
http://rapidshare.com/files/67935460/WooCadWoo2ISO.part2.rar
zarelik
zarelik's picture
Woody 2.0.0.36 ISO
150 MB / Windows
Woodworking and Furniture Design CAD
The Woody allows to create 3D model of furniture product. All parts are plane. They may have curved outline. Parts rest on the axial planes. Moving axial planes with special toggles you can change dimensions of any part and product as whole. Parts are automatically joint correctly each other. The layout of joint depends on selected part type.
The Woody helps designer to install fasteners and fittings. Designer has to select parts to be joined and Woody automatically proposes the list of suitable fasteners and fittings. Selected fitting is installed automatically by one button click. The model of fitting obtains proper orientation in 3D and follows selected parts.
The special wizard built-in Woody provides a possibility to generate models of different kinds of drawers. You have to select kind of drawer only and adjust desirable parameters. Then all modelling is performed in 3D by one button click. When size of furniture product is changed, built-in drawer accomodates to changed size automatically.
In the same way as drawer you can create a system of sliding or bi-fold doors. You have to select type of rails quantity and material of doors. All further modelling is performed automatically.
It is easy to obtaine detailed list of parts and materials with all necessary dimensions specified. Prices are calculated automatically according to data in database, adjustable formulas and coefficients and currency exchange rate.
It is no problem to change color of doors, rails profile or even to change one sliding system to another from other producer.
All drawings, necessary for furniture production are generated automatically by one button click. All dimensions, drill holes, part sizes, edge facing and so on are drawn automatically. Different kinds of dimensioning are provided and adjustable via "Parameters" menu.
The specifications of requred materials and parts of product are generated automatically. They may be exported to database storage to use for cutting layout creation.
The Sawyer software shares database with Woody. It can import data about part dimensions avoiding necessity of manual input of data. Sawyer produces optimized cutting patterns to saw parts from blanks of explicit materials. Sawyer supports stock of materials. It can remember remains and use them in the further sessions of cutting.
Woody 2.0 provides possibility to create and edit spacial scene containing several objects.
Resulting 3D model may be used to perform high resolution image rendering.
VSanja
VSanja's picture
Registrovan dana: 22/01/2010
skinula sam program i da znas-slazem se da nije lako...ali pokusavam i dalje, meni su ove stvari veoma zanimljive...samo bi volela kad bi pronasla slican program za konstrukciju kuce, sve detalje spolja i unutra...imas info o tome?
igamono
igamono's picture
Registrovan dana: 25/01/2010
Laughing out loud pozdrav svima. Evo ima jedan takav program, pogledaj si ovdje http://www.chiefarchitect.com/
caddesigner
caddesigner's picture
Registrovan dana: 08/02/2010
Pozdrav svima,
ukoliko koga vise interesuje Woody neka se javi.
Tutorijale nemam ali sam ga dugo koristio pa mogu biti od koristi.
Ima sve potrebno za manje proizvodjace.
poz
ivanpro
ivanpro's picture
Registrovan dana: 11/06/2010
Imam problem prilikom instalacije.
Ne pokrece program, prijavljuje gomilu errora.
Pomoc
