Warning: File './ssm_restore/watchdog.MYD' not found (Errcode: 13)
query: INSERT INTO watchdog
(uid, type, message, variables, severity, link, location, referer, hostname, timestamp)
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:3900adc087f1f3bb7669aef5930d9248'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/bravarija/koji-aparat-za-varenje-za-pocetnika-ssm', '', '172.69.6.157', 1748747588) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:1198:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Ako moze neko da mi da savet koji aparat za varenje da kupim. Malo sam vario sa co2 aparatom cisto neko upoznavanje za varenjem i fino mi je islo, sada bih napravio kucnu teretanu tipa klupa za trbusnjake neko vratilo za propadanje i zgibove i neku klupu za vezbanje, koristio bih metaljne kutije profile debljine 2-3mm i mozda neke cevi te debljine, sa elektrolucnim varenjem nemam iskustva pa razmisljam da kupim neki aparat i da ucim i usput izvarim neku spravicu &a in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:32b9886675f8b68634783925da2910ab'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/bravarija/koji-aparat-za-varenje-za-pocetnika-ssm', '', '172.69.6.157', 1748747588) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:659:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Moj savet ti je da kupis polovnog rade koncara tip-A23 recimo od nekih 145A ili varex 145 ili 160/180 sa spinglom(pokretnim jezgrom,jes da je kompletno od aluminijuma namotaj ali je extra odradjen) takodje polovnog jer su duplo bolji i istrajniji od ovih navedenih . Ako bas hoces od ovih navedenih novih moj savet je Matrix 200A i samo taj ni jedan vise .Pozdrav</p>\\n ', created = 1748747588, expire = 1748833988, headers = '' in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:5c4143e843073670e03215641424cb6d'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/bravarija/koji-aparat-za-varenje-za-pocetnika-ssm', '', '172.69.6.157', 1748747588) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:438:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Hvala na odgovoru, a ovaj varex video sam prodaje se i nov 160/180, jel je kvalitetniji polovan, a video sam ima na netu varex 135/145 polovan</p>\\n ', created = 1748747588, expire = 1748833988, headers = '', serialized = 0 WHERE cid = '1:5c4143e843073670e03215641424cb6d'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\" in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:d690ba34f44679b4428d2b14a0c2d5e3'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/bravarija/koji-aparat-za-varenje-za-pocetnika-ssm', '', '172.69.6.157', 1748747588) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:529:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Sa Varexom se nećeš prevariti. </p>\\n<p>Ja imam jedan stari Varex, još iz vremena SFRJ, i vrlo sam zadovoljan.<br />\\nRadi sve poslove bez kukanja. Koristim rutilne elektrode Jadran S Ф 2.5 i Elvaco 27R Ф 3.25</p>\\n ', created = 1748747588, expire = 1748833988, headers = '', serialized = 0 WHERE cid = '1:d690ba34f44679b4428d2b14a0c2d5e3'\";s:5:\"%f in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:1921ae43a56350e3f49462bcc33b8d1d'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/bravarija/koji-aparat-za-varenje-za-pocetnika-ssm', '', '172.69.6.157', 1748747588) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:984:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>danas sam gledao neke oglase po netu i vidim prodaje se ocuvan varex 135/145 mt za 160e, a nov varex 160/180 mt je nesto preko 200e, a video sam i einhel BT-EW 200A oko 14000 nov a matrix 200A je oko 12000, e sad koji da uzmem <img src=\\"http://www.samsvojmajstor.com/portal/sites/all/modules/smileys/packs/Roving/smile.png\\" title=\\"Smile\\" alt=\\"Smile\\" class=\\"smiley-content\\"/& in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:beb48f36cf606a719536ffcce243eb78'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/bravarija/koji-aparat-za-varenje-za-pocetnika-ssm', '', '172.69.6.157', 1748747588) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:488:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Varex je - \\"kup UEFA\\"<br />\\nEsab - \\"Liga šampiona\\"<br />\\nEinhell , Matrix, Villager - \\"treća liga zapad\\"</p>\\n<p>Pa ti sad vidi.</p>\\n ', created = 1748747588, expire = 1748833988, headers = '', serialized = 0 WHERE cid = '1:beb48f36cf606a719536ffcce243eb78'\";s:5:\"%fil in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:346a6067e1901162e26ebd97efb4ada5'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/bravarija/koji-aparat-za-varenje-za-pocetnika-ssm', '', '172.69.6.157', 1748747588) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:716:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>ok jasno mi je <img src=\\"http://www.samsvojmajstor.com/portal/sites/all/modules/smileys/packs/Roving/smile.png\\" title=\\"Smile\\" alt=\\"Smile\\" class=\\"smiley-content\\"/>) samo koji od ova dva varexa 135/145mt ili 160/180mt ovaj je jaci ali nisam nasao karakteristike za 135/145 on je stariji model ne prodaje se nov, ne znam dal bi on zadovoljio ovo sto planiram da pravim&a in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:73974d46ada77e882f9cf4c5e9923e71'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/bravarija/koji-aparat-za-varenje-za-pocetnika-ssm', '', '172.69.6.157', 1748747588) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:416:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Pa već imaš odgovor ,ja bih kupio matrix da sam na tvom mestu.<br />\\nA varex nije kup uefa vec isto liga zapad.</p>\\n ', created = 1748747588, expire = 1748833988, headers = '', serialized = 0 WHERE cid = '1:73974d46ada77e882f9cf4c5e9923e71'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\" in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:602e83249df0287c6c72f96f0ad92af1'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/bravarija/koji-aparat-za-varenje-za-pocetnika-ssm', '', '172.69.6.157', 1748747588) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:666:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Uvek je bolje kupiti jači aparat, iako ćeš najviše koristiti tanje elektrode i zavarivati tanje materijale, jer će intermitenca aparata biti duža, u tom slučaju.Odnosno, vreme rada će biti duže, a vreme odmaranja kraće.To bi od prilike bilo kao kad bi fiću vozio punim gasom i neki jači auto sa pola gasa.Učinak je isti ali će se jači aprat manje grejati.</p>\\n ', created = 1748747588, expire = 1748833988, headers = '&am in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:311635b68c9f5be8fad38f70a9f701f7'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/bravarija/koji-aparat-za-varenje-za-pocetnika-ssm', '', '172.69.6.157', 1748747588) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:541:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>[marq=left]<span style=\\"color:blue\\"><span style=\\"font-weight:bold\\"><span style=\\"font-style:italic\\">Uradi sam, ali bez znanja i alata nema zanata!</span></span></span>[/marq]</p>\\n ', created = 1748747588, expire = 1748833988, headers = '', serialized = 0 WHERE cid = '1 in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:f0da8a98e1c6682beb3cd064732e4fc0'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/bravarija/koji-aparat-za-varenje-za-pocetnika-ssm', '', '172.69.6.157', 1748747588) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:409:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Без алата нема заната, a без знања ни најбољи алат неће помоћи..</p>\\n ', created = 1748747588, expire = 1748833988, headers = '', serialized = 0 WHERE cid = '3:f0da8a98e1c6682beb3cd064732e4fc0'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:108;}', in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:b783ce0d7ae34d6e8e6d57929c692a5b'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/bravarija/koji-aparat-za-varenje-za-pocetnika-ssm', '', '172.69.6.157', 1748747588) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:572:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Hvala mnogo sa savetima , razmislicu pa cu odluciti, javicu sta sam uradio <img src=\\"http://www.samsvojmajstor.com/portal/sites/all/modules/smileys/packs/Roving/smile.png\\" title=\\"Smile\\" alt=\\"Smile\\" class=\\"smiley-content\\"/></p>\\n ', created = 1748747588, expire = 1748833988, headers = '', serialized = 0 WHERE cid = ' in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:2d3496832ba77f0237ba5b37a856f0cc'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/bravarija/koji-aparat-za-varenje-za-pocetnika-ssm', '', '172.69.6.157', 1748747588) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:593:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Epilog jucerasnjeg dana </p>\\n<p>Vadim iz kutije u jedoj veleprodaji Varin 1705 , ukljucim ga osim ventilatora ne radi nista drugo , vadim drugi Varin 1705 iz kutije mrtav totalno , vadim treci Varin 2000 in , takodje totalno mrtav ..... I tu odsutajem od daljeg testiranja .....</p>\\n ', created = 1748747588, expire = 1748833988, headers = '', serialized = 0 WHERE cid = '1:2d349683 in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:f37d6a905ef62dfb1fc58173a5704d2f'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/bravarija/koji-aparat-za-varenje-za-pocetnika-ssm', '', '172.69.6.157', 1748747588) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:406:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Од свих машина, најволијем Веселу Машину<br />\\nА и ЛУГЕР П08</p>\\n ', created = 1748747588, expire = 1748833988, headers = '', serialized = 0 WHERE cid = '1:f37d6a905ef62dfb1fc58173a5704d2f'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:108;}&# in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:b23876703b135025219247289402ae6d'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/bravarija/koji-aparat-za-varenje-za-pocetnika-ssm', '', '172.69.6.157', 1748747588) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:876:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p><a href=\\"https://www.facebook.com/tenzor1/\\" title=\\"https://www.facebook.com/tenzor1/\\">https://www.facebook.com/tenzor1/</a><br />\\n<a href=\\"https://tenzorisanje.wordpress.com/\\" title=\\"https://tenzorisanje.wordpress.com/\\">https://tenzorisanje.wordpress.com/</a><br />\\n<a href=\\"h in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:59b3f5cefd335493944a3ddbc925716c'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/bravarija/koji-aparat-za-varenje-za-pocetnika-ssm', '', '172.69.6.157', 1748747588) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:323:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>otkud da ti kupuješ varina</p>\\n ', created = 1748747588, expire = 1748833988, headers = '', serialized = 0 WHERE cid = '1:59b3f5cefd335493944a3ddbc925716c'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:108;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/bravarija in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:314947b50179972bb951410e8d59e92c'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/bravarija/koji-aparat-za-varenje-za-pocetnika-ssm', '', '172.69.6.157', 1748747588) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:600:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Ma ne verujem da kupuje, on ti je ko terminator, koji aparat preživi u njegovim rukama, taj će trajati. <img src=\\"http://www.samsvojmajstor.com/portal/sites/all/modules/smileys/packs/Roving/wink.png\\" title=\\"Wink\\" alt=\\"Wink\\" class=\\"smiley-content\\"/></p>\\n ', created = 1748747588, expire = 1748833988, headers = '', serialize in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
VALUES
VALUES
VALUES
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:1ac1a000aa093e044a1b6a7a49991f5f'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/bravarija/koji-aparat-za-varenje-za-pocetnika-ssm', '', '172.69.6.157', 1748747588) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:849:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Ma nisam imao nameru da kupujem Varina ,vec je moj drugar vlasnik te veleprodaje . Pa mu se desilo da su mu dva Varina vracena otprilike 2 sata posle kupovine i to sa istim simptomima kao i ova tri koje sam ja probao . Pa me drugar pozvao da prverimo sve aparate da bi sprecio sve eventualne problememe oko reklamacija , jer kod nas jos uvek nije zaziveo sistem zamene neispravnog uredjaja . E sad zamislite kakava je osecaj nekome ko je izbrojao cca 600 e i posle 20 m in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
VALUES
VALUES
VALUES
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:e47785e6b138e8988866ffd8b73280a5'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/bravarija/koji-aparat-za-varenje-za-pocetnika-ssm', '', '172.69.6.157', 1748747588) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:358:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Ja uporno pričam da varstroj nije ni zašta a ljudi ne veruju</p>\\n ', created = 1748747588, expire = 1748833988, headers = '', serialized = 0 WHERE cid = '1:e47785e6b138e8988866ffd8b73280a5'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:108;}', 3, '', 'http://www.samsvojmajstor.co in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:da8d78ce3ea78cbc7c1df497bf321223'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/bravarija/koji-aparat-za-varenje-za-pocetnika-ssm', '', '172.69.6.157', 1748747588) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:674:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Za početak ti preporučujem ovaj stari končar<br />\\n<a href=\\"http://www.limundo.com/kupovina/Masine-i-Alati/Za-zavarivanje/Aparat-za-zavarivanje/4286705\\" title=\\"http://www.limundo.com/kupovina/Masine-i-Alati/Za-zavarivanje/Aparat-za-zavarivanje/4286705\\">http://www.limundo.com/kupovina/Masine-i-Alati/Za-zavarivanje/Aparat-za-...</a></p>\\n ', created = 174 in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:9b451b81d7258c4ee646e81702df2f7d'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/bravarija/koji-aparat-za-varenje-za-pocetnika-ssm', '', '172.69.6.157', 1748747588) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:2065:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Aparat je extra , imam dva moja ovakva komada i rade fenomenalno ali na licitaciji se covek izjasnio kao da ne zna da li su ispravni pa bi bilo dobro proveriti sa njim kada ga ukljuci da li se cuje da zuji i radi jer mi je bilo sumnjivo to da ne zna da li ispravan uopste i ujedno se time ogradi od toga kada ga kupis i proveris da nije jbg. Inace je kompletno bakarni namotaj , tezak je oko 25kg odnosno tacno 23 <img src=\\"http://www.samsvojmajstor.c in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:5d9632a86d350b341bbdb6482234401b'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/bravarija/koji-aparat-za-varenje-za-pocetnika-ssm', '', '172.69.6.157', 1748747588) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:1617:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>I da dodam da inverteri Varstroj nisu za potcenjivanje dal bili samo REL ili TIG-REL aparati u pitanju , poznajem ih u prste kao i vecinu invertera sa kojima ste se mozda sreli ili niste ili pa niste mozda nikada ni culi za njih <img src=\\"http://www.samsvojmajstor.com/portal/sites/all/modules/smileys/packs/Roving/lol.png\\" title=\\"Laughing out loud\\" alt=\\"Laughing out loud\\" class=\\"smil in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:401ab9811cbee43941fb81d7acfd2066'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/bravarija/koji-aparat-za-varenje-za-pocetnika-ssm', '', '172.69.6.157', 1748747588) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:634:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Mogao bih slobodno napisati da je ta intermitenca kod Varina \\"naduvana \\" pogotovo ako se poredi sa aparatima istih ili vrlo slicnih karakteristika , problema sa radom na agregatima , produznim kablovima i velikoj ceni Varin je vrlo skupa igracka , uz to vrlo je malo firmi koje se zavarivanjem bavi na bazi Varin aparata .</p>\\n ', created = 1748747588, expire = 1748833988, headers = '', serialized = in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
VALUES
VALUES
VALUES
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:11bb9f49cba7f227161dacfac46708cb'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/bravarija/koji-aparat-za-varenje-za-pocetnika-ssm', '', '172.69.6.157', 1748747588) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:463:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Invertori starije generacije su fenomenalni ali sa varinom nešto mi je sumnjivo,radio sam i sa onim starijim i sa njim i razlika je velika u korist prethodnih serija.</p>\\n ', created = 1748747588, expire = 1748833988, headers = '', serialized = 0 WHERE cid = '1:11bb9f49cba7f227161dacfac46708cb'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/ca in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:a57571275d3a9f1ff08b4198112aef0a'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/bravarija/koji-aparat-za-varenje-za-pocetnika-ssm', '', '172.69.6.157', 1748747588) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:1380:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Gledam oglase po netu za nove i polovne aparate, a limundo mi ne uliva neko poverenje <img src=\\"http://www.samsvojmajstor.com/portal/sites/all/modules/smileys/packs/Roving/smile.png\\" title=\\"Smile\\" alt=\\"Smile\\" class=\\"smiley-content\\"/> a ja sam iz bg pa ne mogu licno da se uverim u ispravnost onog koncara sa oglasa, i einhell od 200A je 24kg tezak i on oko a matrix 2 in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:63bfaf7077bbb23bd7f07d62ea69478e'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/bravarija/koji-aparat-za-varenje-za-pocetnika-ssm', '', '172.69.6.157', 1748747589) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:857:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>naisao sam na onaj aparat <a href=\\"http://www.limundo.com/kupovina/Masine-i-Alati/Za-zavarivanje/AKCIA-ELEKTROAPARAT-MALI-PRENOSIVI-KONCAR-A-13-90A-RADI/4275349\\" title=\\"http://www.limundo.com/kupovina/Masine-i-Alati/Za-zavarivanje/AKCIA-ELEKTROAPARAT-MALI-PRENOSIVI-KONCAR-A-13-90A-RADI/4275349\\">http://www.limundo.com/kupovina/Masine-i-Alati/Za-zavarivanje/AKCIA-ELEK...</a><br />\\n in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:eb6b4227a234bf98e11f44026261e083'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/bravarija/koji-aparat-za-varenje-za-pocetnika-ssm', '', '172.69.6.157', 1748747589) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:553:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>mislim za tu kucnu teretanu koju imam zelju da napravim <img src=\\"http://www.samsvojmajstor.com/portal/sites/all/modules/smileys/packs/Roving/smile.png\\" title=\\"Smile\\" alt=\\"Smile\\" class=\\"smiley-content\\"/></p>\\n ', created = 1748747589, expire = 1748833989, headers = '', serialized = 0 WHERE cid = '1:eb6b4227a234bf98e in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:3cd4d57fb4548ad9a7077dabc840c701'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/bravarija/koji-aparat-za-varenje-za-pocetnika-ssm', '', '172.69.6.157', 1748747589) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:735:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Kupovati polovan aparat za varenje je kupovina macke u dzaku , vrlo je moguce da je aparat pred crkavanje i sta onda ....<br />\\nOdes lepo u Woby kupis onaj preporuceni Matrix 200 i nema da te boli glava , a posto ce biti za kucnu upotrebu ima da te sluzi ihaj .<br />\\nTo sa tezinom aparata je nekad vazilo kad nismo znali za bolje , sada jedan kvalitetan inverter tezi oko 6-7 kg a pojede jedno 20 kom Matrixa, Varina .....</p&am in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:f37d6a905ef62dfb1fc58173a5704d2f'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/bravarija/koji-aparat-za-varenje-za-pocetnika-ssm', '', '172.69.6.157', 1748747589) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:406:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Од свих машина, најволијем Веселу Машину<br />\\nА и ЛУГЕР П08</p>\\n ', created = 1748747589, expire = 1748833989, headers = '', serialized = 0 WHERE cid = '1:f37d6a905ef62dfb1fc58173a5704d2f'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:108;}&# in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '3:b23876703b135025219247289402ae6d'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/bravarija/koji-aparat-za-varenje-za-pocetnika-ssm', '', '172.69.6.157', 1748747589) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:415fada13db2b4751e07a616708e7596'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/bravarija/koji-aparat-za-varenje-za-pocetnika-ssm', '', '172.69.6.157', 1748747589) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:513:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>ok jasno <img src=\\"http://www.samsvojmajstor.com/portal/sites/all/modules/smileys/packs/Roving/smile.png\\" title=\\"Smile\\" alt=\\"Smile\\" class=\\"smiley-content\\"/> hvala</p>\\n ', created = 1748747589, expire = 1748833989, headers = '', serialized = 0 WHERE cid = '1:415fada13db2b4751e07a616708e7596'\";s:5:\&q in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:50b1d518bba68801b16141c6290ef796'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/bravarija/koji-aparat-za-varenje-za-pocetnika-ssm', '', '172.69.6.157', 1748747589) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:744:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Sto se mene tice Uzmi varex 135 145 mt koji je oko 150E polovan ja imam 4 aparata varex 135 145 mt jedan varex 160 210mt oba su odlicna jedan veliki koncar samo neznam koliko je ampera 350 ili 400 sva 3 su odlicna i jedan pokvaren od 145 A varstroj ali nije mt tako da varstroj .<br />\\nainhel i ti po buvljacima nisu nista jer sam dobio jedan einhel od 145 A i nije mogao na max amperazi da vari sa 3,25 vari ali slabo dok varex 145 jede.</p&am in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:a70f10ab0e501ccb76d3c9aac7338cd2'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/bravarija/koji-aparat-za-varenje-za-pocetnika-ssm', '', '172.69.6.157', 1748747589) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:686:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Molio bih sve ucesnike diskusije da ne pisu svasta i da se ne frljaju sa cenama . Za 150 e se moze kupiti napr NOV Varex 162 to preko skupljih onlajn prodaja ....<br />\\n<a href=\\"http://www.alatiimasine.com/proizvodjaci/varstroj/\\" title=\\"http://www.alatiimasine.com/proizvodjaci/varstroj/\\">http://www.alatiimasine.com/proizvodjaci/varstroj/</a></p>\\n ', c in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
VALUES
VALUES
VALUES
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:92353658ce9991b2c4ebc3bba9382006'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/bravarija/koji-aparat-za-varenje-za-pocetnika-ssm', '', '172.69.6.157', 1748747589) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:2429:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Tenzore druze ocigledno nisi upucen u kvalitet ovih aparata koje savetujes da se kupe , ovi aparati su sada radjeni toliko jadno da bi ih trebalo zakonom zabraniti .U njima je bakarna zica primara debljine 1.35mm-1.8mm (zavisi koji je aparat u pitanju) sto je jadno pa nema gde vise ,a sekundar debljine 2.95mm-3.5mm pa ti vidi , elektroda je deblja od sekundarne zice.<br />\\n Jes da cena nije bas oko 150 eur ali veruj mi da bih dao pre te pare za sta in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:b9b93b5301fd8c03590c64b19acf5e5a'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/bravarija/koji-aparat-za-varenje-za-pocetnika-ssm', '', '172.69.6.157', 1748747589) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:883:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Priznajem da nisam upucen u kvalitet Varstroj aparata , jer tesko je biti upucen u nesto cega nema ...<br />\\nMoj post oko spominjanja Varexa se samo odnosio na CENU polovnog aparata . Za mene licno su svi ti Varexi , Matrixi , kojekakve budzevine i slicno totalno nebitne stvari u zivotu .<br />\\nUostalom referentni sistemi nas priucenih zavarivaca i majstora /viklera se uvek razlikuju ..<br />\\nUostalom ja sam se \\&a in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
VALUES
VALUES
VALUES
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:a1e87574f3f1bbe09a0c17628f22a8ac'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/bravarija/koji-aparat-za-varenje-za-pocetnika-ssm', '', '172.69.6.157', 1748747589) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:2464:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>ahahaha u pravu si da jesu budzevine ali su ujedno i hoby aparati koji su itekako dovoljni jednom domacinstvu da dnevno sa njim moze raditi sat ili dva oko sredjivanja ili eventualno izrade neke bravarije , vrata , prozora , kapije itd. , nisu za neku ozbiljnu proizvodnju ili da rade po 8 sati dnevno.<br />\\n- druga stvar koju moram pomenuti ,a bode mi oci u tvom postu je kod pominjanja \\'\\'priucenih\\'\\' majsto in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '1:377d0a7f60228b7c4165ce8250ca813e'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/bravarija/koji-aparat-za-varenje-za-pocetnika-ssm', '', '172.69.6.157', 1748747589) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:721:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = ' <p></p><p>Jesil ti pismen il oces da me zivciras <img src=\\"http://www.samsvojmajstor.com/portal/sites/all/modules/smileys/packs/Roving/smile.png\\" title=\\"Smile\\" alt=\\"Smile\\" class=\\"smiley-content\\"/><br />\\nNapisao sam \\"nas pricuneih zavarivaca \\" i to se pre svega odnosilo na par ljudi( I mene ) koji pisu o zavarivanju a nemamo formalno zav in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
VALUES
VALUES
VALUES
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '2:abfecc63f09f063c306e2753273f32e4'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/bravarija/koji-aparat-za-varenje-za-pocetnika-ssm', '', '172.69.6.157', 1748747589) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:942:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = '<p><iframe id=\\'a431a3a0\\' name=\\'a431a3a0\\' src=\\'https://adserver.samsvojmajstor.com/adserver/www/delivery/afr.php?zoneid=26&amp;cb=9900435235423422\\' frameborder=\\'0\\' scrolling=\\'no\\' width=\\'728\\' height=\\'90\\'><a href=https://adserver.samsvojmajstor.com/adserver/www/delivery/ck.php?n=afcbc006&amp;cb=9900435235423422\\� in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '2:ca011fdebe3a51dea5859d4aba19f564'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/bravarija/koji-aparat-za-varenje-za-pocetnika-ssm', '', '172.69.6.157', 1748747589) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:956:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = '<p><iframe id=\\'a354bc39\\' name=\\'a354bc39\\' src=\\'https://adserver.samsvojmajstor.com/adserver/www/delivery/afr.php?zoneid=27&amp;cb=002874370149734552\\' frameborder=\\'0\\' scrolling=\\'no\\' width=\\'234\\' height=\\'160\\'><a href=\\'https://adserver.samsvojmajstor.com/adserver/www/delivery/ck.php?n=aa83fdd3&amp;cb=0028743701 in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:195:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: SELECT data, created, headers, expire, serialized FROM cache_filter WHERE cid = '2:64a277481435f3c6a7b18eb6fa57f957'\";s:5:\"%file\";s:76:\"/home/admin/domains/samsvojmajstor.com/public_html/portal/includes/cache.inc\";s:5:\"%line\";i:25;}', 3, '', 'http://www.samsvojmajstor.com/portal/forums/uradi-sam/bravarija/koji-aparat-za-varenje-za-pocetnika-ssm', '', '172.69.6.157', 1748747589) in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135
VALUES
(0, 'php', '%message in %file on line %line.', 'a:4:{s:6:\"%error\";s:12:\"user warning\";s:8:\"%message\";s:868:\"Table 'ssm_restore.cache_filter' doesn't exist\nquery: UPDATE cache_filter SET data = '<p><iframe id=\\'a694a55c\\' name=\\'a694a55c\\' src=\\'https://nepremicnine.click/www/delivery/afr.php?zoneid=99&amp;cb=43241234\\' frameborder=\\'0\\' scrolling=\\'no\\' width=\\'300\\' height=\\'600\\'><a href=\\'https://nepremicnine.click/www/delivery/ck.php?n=a9f8f8a5&amp;cb=63456\\' target=\\'_blank\\'& in /home/admin/domains/samsvojmajstor.com/public_html/portal/includes/database.mysql.inc on line 135 koji aparat za varenje za pocetnika ssm | www.samsvojmajstor.com
Ako moze neko da mi da savet koji aparat za varenje da kupim. Malo sam vario sa co2 aparatom cisto neko upoznavanje za varenjem i fino mi je islo, sada bih napravio kucnu teretanu tipa klupa za trbusnjake neko vratilo za propadanje i zgibove i neku klupu za vezbanje, koristio bih metaljne kutije profile debljine 2-3mm i mozda neke cevi te debljine, sa elektrolucnim varenjem nemam iskustva pa razmisljam da kupim neki aparat i da ucim i usput izvarim neku spravicu , gledao sam u woby hausu matrix aparate ili enhel ili mozda neki varex od varstoja, samo ne znam koju amperazu i model aparata da uzmem, ako ima neko neki savet kakav aparat bi mi bio dovoljan za ovakve poslove kucne u varijanti ssm.
danas sam gledao neke oglase po netu i vidim prodaje se ocuvan varex 135/145 mt za 160e, a nov varex 160/180 mt je nesto preko 200e, a video sam i einhel BT-EW 200A oko 14000 nov a matrix 200A je oko 12000, e sad koji da uzmem ) koncar nisam nasao po oglasima , hvala mnogo na savetima
ok jasno mi je ) samo koji od ova dva varexa 135/145mt ili 160/180mt ovaj je jaci ali nisam nasao karakteristike za 135/145 on je stariji model ne prodaje se nov, ne znam dal bi on zadovoljio ovo sto planiram da pravim
Ma nisam imao nameru da kupujem Varina ,vec je moj drugar vlasnik te veleprodaje . Pa mu se desilo da su mu dva Varina vracena otprilike 2 sata posle kupovine i to sa istim simptomima kao i ova tri koje sam ja probao . Pa me drugar pozvao da prverimo sve aparate da bi sprecio sve eventualne problememe oko reklamacija , jer kod nas jos uvek nije zaziveo sistem zamene neispravnog uredjaja . E sad zamislite kakava je osecaj nekome ko je izbrojao cca 600 e i posle 20 min shvatio da mu aparat ne radi , a onda aparat ne servis , pa cekaj , ovo ono ....
Aparat je extra , imam dva moja ovakva komada i rade fenomenalno ali na licitaciji se covek izjasnio kao da ne zna da li su ispravni pa bi bilo dobro proveriti sa njim kada ga ukljuci da li se cuje da zuji i radi jer mi je bilo sumnjivo to da ne zna da li ispravan uopste i ujedno se time ogradi od toga kada ga kupis i proveris da nije jbg. Inace je kompletno bakarni namotaj , tezak je oko 25kg odnosno tacno 23 da budemo precizni i servis njega nije uopste jeftin , Sekundar je malo zajeban za motanje(tesko se nalazi flah ako se skroz sprzio usled kratkog spoja i prekinuo vezu) ,a i primara ima dosta tezinski . Inace sam jedan takodje kupio na aukciji i navodno nije znao da je ispravan pa sam ga servisirao i ujedno mu izvukao izvode za starter i dogradio diode,a riknuo mi je primar saamo tako i izbacivali osiguraci cim se ukljuci pa zato kazem treba proveriti sta se desava kada ga ukljuci u struju , da li zuji ili se ne cuje nista ili izbacuju osiguraci ili prodavac nece nista o tome da kaze pa onda budete sigurni da nesto krije ,a kao satra ne zna da li je ispravan ili ne .Pozdrav
I da dodam da inverteri Varstroj nisu za potcenjivanje dal bili samo REL ili TIG-REL aparati u pitanju , poznajem ih u prste kao i vecinu invertera sa kojima ste se mozda sreli ili niste ili pa niste mozda nikada ni culi za njih i od sve te skupine invertera mogu reci da Varstroj zauzima mesto u gornjem delu spiska pri vrhu. Servis ne zahteva neke specificne delove kao kempi na primer gde moduli nekih fetova kostaju po 120-130 eur , ili Telwina kao i Essaba cije delove moras naruciti preko ako ih ne mozes naci kod par prodavaca u zemlj(ako trenutno nemaju na lageru) itd itd. Sema je dobra radjeno je da potraje, zasticeni su svi delovi od pregrevanja , intermitenca je velika jednostavno je sasvim solidan aparat . Ovo sto sam napisao se odnosi samo na invertere ,a ne za ostale aparate co2 ili REl gde je u pitanju obican trafo jer su tu bas bas stedeli u materijalu i varijante su bas Hoby tipa .
Inace ovo je moje misljenje kao servisera mada treba saslusati i misljenje korisnika , a makar kod mene su ga korisnici hvalili i imali dobrog iskustva sa njim godinama .Pozdrav
Mogao bih slobodno napisati da je ta intermitenca kod Varina "naduvana " pogotovo ako se poredi sa aparatima istih ili vrlo slicnih karakteristika , problema sa radom na agregatima , produznim kablovima i velikoj ceni Varin je vrlo skupa igracka , uz to vrlo je malo firmi koje se zavarivanjem bavi na bazi Varin aparata .
Gledam oglase po netu za nove i polovne aparate, a limundo mi ne uliva neko poverenje a ja sam iz bg pa ne mogu licno da se uverim u ispravnost onog koncara sa oglasa, i einhell od 200A je 24kg tezak i on oko a matrix 200A je 18,5kg, negde sam procitao da je kao bolje kad je tezi aparat, kakvo je vase misljenje o ovome, video sam i villager od 200A on je 23kg i najeftiniji je jel je neko upoznat sa ovom markom vidim da se razumete u alat pa verovatno sam ja smesan sa ovim ))
Molio bih sve ucesnike diskusije da ne pisu svasta i da se ne frljaju sa cenama . Za 150 e se moze kupiti napr NOV Varex 162 to preko skupljih onlajn prodaja .... http://www.alatiimasine.com/proizvodjaci/varstroj/
Jes da cena nije bas oko 150 eur ali veruj mi da bih dao pre te pare za stari nego za novi aprat , ako mi verujes .Varex 152 ima samo tri amperaze , jezgro je tipa EI150 , primarna zica 1.3mm sekundarna 2.9mm malte ne kao debljina elektrode , aparat je nemoguce pojacati i posle dve tri elektrode se gasi , taj aparata se kod mene u radionici ne servisira to jest odbijam da se prihvatim tog posla , aparat 162 je malo jaca varijanta aparata 152 samo se razlikuje sto je uradjen tako da se struja regulise pokretnim jezgrom na spinglu i zica sa kojom je motan je za nijansu deblja od svoje jadnije verzije 152 , znaci katastrofa . Opet kazem ako neko zeli koliko toliko dobar neka kupi Matrix 200 ili Varstroj 180 , varstroj 160/180 ili po mojoj preporuci i uz garanciju da se nece pokajati za svaki dinar sto ga plati je varstroj 160/210 izuzetno solidna masina koja se moze naci za te pare , cak je klasu bolja od predhodnih koje sam naveo. Inace poznajem ih sve u prste , sve sam ih servisirao, prepravljao , dogradjivao startere , punjace , ispravljanje struje , pojacavanje itd. gomila stvari , cak sam Matrix-u 200 ubacio diode i mogao je topiti 2.5 bazicnu ali uz malu prepravku sekundara to jest povecavanjem napona , ako nadjem slike prepravke postavicu ovde . U par tih aparata sam ugradio elektronsku regulaciju struje i to na par komada primarnu regulaciju struje zavarivanja , a u par komada elektronska regulacija sa tiristorima u sekundaru i imao je pored AC i DC izlaz kao opciju zavarivanja Pozdrav
Uostalom ja sam se "na slepo " slozio sa tvojom preprukom oko Matrixa 200 , za mene licno to je aparat kojim se ne bih posluzio osim u krajnjoj nuzdi ....
- druga stvar koju moram pomenuti ,a bode mi oci u tvom postu je kod pominjanja ''priucenih'' majstora pa bilo zavarivaca ili viklera jer konkretno u mom slucaju je da ja nisam priucen jbg . Na zalost nisam vikler pa da ti do dokumentujem ali dodirujem i tu oblast jer uglavnom rad sa kojim sam zavrsio skolovanje se odnosi na tu oblast ,a to je da sam projektovao generator-motor sa svim proracunima za njegovu izradu i exploataciju . Uglavnom je moja uza specijalnost automatika - elektronika u industriji mada volim ovaj posao kojim se bavim i stojim iza svake reci koju iznesem ovde kao i iza svake napisane reci kada sam stojao kod atesta ovih uredjaja pa zato bez zamerki mi rec ''priuceni'' malo zasmeta jer sam dosta gulio da naucim da nesto znam , a na zalost nisam imao nikoga da mi skrati put i pomogne oko toga vec se skoro jednu deceniju vucem po raznim firmama i prodajem neki moj rad da ne kazem znanje za sitne pare . Inace nikada nisam kopirao neciji rad i izradjvao ga pa se hvalio time jer sam uvek pesaka od starta sam na papiru bacio sve , izracunao , kasnije odradio , dosta tstirao modifikovao da bude bas kako treba jer nikada ne ispada na papiru kao u realnosti sve idealno pa kada sam se uverio da zadovoljava neke moje standarde (a veruj mi visoki su u ovoj oblasti ) onda sam dozvolio sebi da to nekome prodam i uradim .Pozdrav
Napisao sam "nas pricuneih zavarivaca " i to se pre svega odnosilo na par ljudi( I mene ) koji pisu o zavarivanju a nemamo formalno zavarivacko obrazovanje .
